May 28, 2012, 09:36:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  after the crash - episode 2
Pages: 1   Go Down
Print
Author Topic: after the crash - episode 2  (Read 169 times)
Fred_evans
Active Member
Offline Offline
View Profile
« on: December 22, 2011, 03:45:34 AM »
I am not going to reinstall because I am scared of loosing the calibrations
Can I re install and not have to recalibrate everythinh again
regards fred evans
think of the trees-- use both sides of the computer paper
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: December 22, 2011, 08:28:16 AM »
Hi Fred,
All of your previous set-up will be stored in the .xml file (named as the profile you are using .xml) and located in you Mach3 folder. Copy this file, save it somewhere safe (memory stick is good), then use it to over - right the new .xml file after the re-install. It is also wise to keep a copy of your license file and screen set, just in case everything gets deleted.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
