May 28, 2012, 10:40:21 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Arrow 500 retrofit
Pages: 1   Go Down
Print
Author Topic: Arrow 500 retrofit  (Read 201 times)
Machellar
Active Member
Offline Offline
View Profile
« on: December 20, 2011, 03:29:52 PM »
good day all
just finishing up the retrofit on our Romi/Bridgeport lathe - new Mach3 controller - new Kollmorgen drives and motors with a Hitachi VFD - it's been a challenge but, we're just about there - need the spindle speed tweaked and i can start cutting again...
next is our Arrow 500 - same thing, new Kollmorgen drives and motors. we've decided to go 480v on all motors and drives meaning we had to have the original spindle motor rewound from 230v to 480v since, they say, there is no such thing as a 12000 rpm motor that runs 480v. There will be an REFU drive controlling the spindle motor (REFU is a German company). By the way - the guys that did the rewind on the motor did a sweet job!  Tongue
What we have learned from the Romi refit will make this one quite a bit easier and faster... until we get to the 21 tool ATC - how the heck is this going to work?  Huh
I've been reading through some of the "tool changer" posts and have some idea but, not really.
I know we'll be using a PLC (Allen/Bradley) that we carry in our central stores but i'm not sure were to start
any advice/direction would be appreciated
thanks
Mark
« Last Edit: December 20, 2011, 03:33:09 PM by Machellar » Logged
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: December 20, 2011, 06:03:02 PM »
If the PLC has ModBUS then it shouldnt be too hard Smiley
dresda
Active Member
Offline Offline
View Profile
« Reply #2 on: December 20, 2011, 07:26:14 PM »
These guys retrofit The arrow with a PC based control. http://manufacturingnewsweb.com/archives/controls/dec06/maintenance_tech.htm
Does your machine have the CT control from the UK or the control now owned by Vickers?
Ray.
Machellar
Active Member
Offline Offline
View Profile
« Reply #3 on: December 21, 2011, 08:07:08 AM »
thanks Hood - i'll check that out - nice to have a place to start
Ray - the old control is a A2100 - Vickers
thanks for the link - i may end up giving them a call
Mark
Pages: 1   Go Up
Print
Jump to:
