Hello Guest it is June 12, 2026, 01:43:54 PM
Author Topic: Connecting a printer  (Read 7830 times)
« on: December 16, 2011, 05:14:38 AM »
Hi I'm using a 10 year old Dell computer to run my Mach3 software through a standard printer port (25pin). Before I connect a printer into the system via a usb port can someone advise that this will not effect my connection between the computer and my CNC Mill. E.G Mach will not get confused when I try to print out a copy of any programs. Don't want to upset my set up which is running perfectly.
Re: Connecting a printer
« Reply #1 on: December 16, 2011, 05:41:38 AM »
I have connected my printer and other things to the PC  which runs my machines and never had a problem.
Using them when actually having  Mach control a program should not be done.
Your pc may behave differently.
« Reply #2 on: December 16, 2011, 09:27:02 AM »
Since it is a USB printer, can't you just "pull the plug" on the USB cable to the printer unless printing?  Better safe than ruin a long job.  Windows frequently does strange, unexpected things.
John Champlain
www.picengrave.com
  •  9,356 9,356
« Reply #3 on: December 18, 2011, 10:08:00 AM »
Hi Jim,
If your CNC is all running OK then don't risk the printer connection.
Why not use a memory stick or something similar to transfer a copy of the program to another computer which is connected to a printer ??
nb. If you don't have another computer - It's Christmas time  ;D
