Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 10:34:45 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
G00 is now faster than allowed by motor tuning settings? WT*?
Pages:
1
Go Down
« previous
next »
Author
Topic: G00 is now faster than allowed by motor tuning settings? WT*? (Read 215 times)
natefoerg
Active Member
Offline
on:
December 14, 2011, 11:41:40 PM »
So, I have had mach 3 running a stepper converted hardinge CHNC lathe. Mach has (until today) been only controlling Z and X axis movement.
Today I finally got my collet closer running with a solenoid and a relay board through mach. additionally, I now have a VFD running the spindle through mach using my BOB's 0-10Vdc output. the only other thing I changed was to set up a mechanical estop.
These three new additions work very well, and relaibly. so far.
when I tried to run a working piece of code (created in Bobcad ver 23) I was stunned to find that my G00 moves were now so rapid that the G203V's I run were faulting out.
My motor tuning settings are the same as they always were, but now my G00 is super fast.
If I change my steps per for the Z axis from 40000 (the original always has worked correctly number) to 10000, the G00 moves are still very rapid, but are slow enough to not fault the G203v.
this has led me to believe that somehow, my settings for the max motor speed allowed are all messed up. I dont get it, I thought that the max motor speed (rapid) was a function of the motor settings tab. How can Mach be overriding this?
I tried switching a spare G203V into the system, but the G00 being wildly fast still happened.
I am attaqching 2 xml's one from 10 18 2011 which worked just fine when I saved it, and the other from today that allows me to use the CC, VFD spindle and EStop switch.
I hope you guys can help!
Mach3Turn10182011.xml
(79.22 KB - downloaded 8 times.)
Mach3Turn12142011.xml
(108 KB - downloaded 8 times.)
Active Member
Offline
Carnoustie, Scotland
Re: G00 is now faster than allowed by motor tuning settings? WT*?
Reply #1 on:
December 15, 2011, 01:49:45 PM »
Something wrong if changing your steps per unit allows you to use the machine as that would alter not just the rapid speed but the distance travelled.
First things frst we need to find out what your steps per unit should be.
What encoder count do you have?
Do you have any gearing between motor and screw?
What is the pitch of the screws?
You also have an A axis enabled but dont have anything set for steps per unit, Velocity, Accel. What are you using the A axis for?
Also what version of Mach are you using?
natefoerg
Active Member
Offline
Reply #2 on:
December 15, 2011, 03:10:27 PM »
Version R3.042.040
A axis was enabled from some time ago, as I was testing a stepper controlled spindle on the lathe. I have since abandoned that idea and have just never unchecked the A axis enabled.
My steps for the X and Z have always been at 40000. the ballscrews run on a 5:1 reduction as the machine originally ran Servos. I retrofitted with steppers.
The system has been running perfectly for several years. Only when I added the hardware hookups and changed settings yesterday did I get a G00 that would cause monstrously fast rapids.
I did try and run the spindle calibration utility several times yesterday unsuxcessfully. I suspect that this somehow caused the issue. I am going to try to reinstall the same version of mach3, and see if that fixes it.
natefoerg
Active Member
Offline
Reply #3 on:
December 15, 2011, 04:31:49 PM »
Well, a fresh install of Mach3 and the SS plugin seems to have fixed the problem. I think I somehow corrupted the Mach or SS installation...
Few bugs to work out, but I think I am almost there!
Thanks again Hood!!!!!!
Active Member
Offline
Reply #4 on:
December 16, 2011, 02:57:13 AM »
Sorry, misread, thought you said you had servos.
Good you got it going
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
