Hello Guest it is June 11, 2026, 10:22:22 AM
Author Topic: Particular thread won't load  (Read 24983 times)
Re: Particular thread won't load
« Reply #1 on: December 14, 2011, 03:11:59 PM »
What is this post about?
« Reply #2 on: December 14, 2011, 04:12:51 PM »
In the title, "Particular thread won't load"
Won't load here either.
Russ
« Reply #3 on: December 14, 2011, 04:21:51 PM »
Won't load here so not sure.... but..... Russ said it was all about Brett and needed to be censored.
« Reply #4 on: December 14, 2011, 04:44:07 PM »
Loading fine here.  Hmmmmmm.
*(&^(*&^(*&^(*&^^   ;D  ^%%%$#$^%
Offline Vogavt
  •  260 260
« Reply #5 on: December 14, 2011, 06:32:43 PM »
I found it when doing a search for "kernel speed adjust". The thread topic is showing as "step and direction spindle" and was started by "bondeoca" in the General Mach Discussion thread.
Looks like it was originally posted on April 30, 2007, 06:58:17 PM
Hope this helps.
Still not loading for me.
UPDATE! I can get to page two of the thread, but not back to page 1.
See if this will load for you (Page 2).
http://www.machsupport.com/forum/index.php/topic,3055.msg23803.html#msg23803
Advanced Search Result
in General Mach Discussion
step and direction spindle by bondeoca
...  am redoing the head on a supermax mill and I am using the uhu servo drives and a 2  ...
... /2
treadmill motor for spindle drive.Just playing around with it I  ...
...  get the spindle to operate
correctly with latest ver  ...
...  360 count encoder which works out 1440 steps per rev,
but I am using the step  ...
...  on the drive to bring it back to 360 steps per rev.I first set it up as
the z  ...
...  to check for correct steps per rev and all worked fine,but when  ...
...  up as the spindle I have
to set the steps to 1440 in  ...
...  correct speed.I just set rpm to 60 and count
how many revs in a minute and I  ...
...  getting around 48.As I understand it steps shold be steps per rev
and vel. ...
« Last Edit: December 14, 2011, 06:45:16 PM by Vogavt »
