Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 10:30:23 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Motor Tuning Help
Pages:
1
Go Down
« previous
next »
Author
Topic: Motor Tuning Help (Read 274 times)
Airplane Guy
Active Member
Offline
Motor Tuning Help
on:
December 12, 2011, 03:46:56 PM »
I need some help. I have been trying to get my router table to run for some time now, embarrased about the actual time. I cannot seem to get my stepper motors to run smothly while in program at all. I also got stuck trying to get a 20 yo machine to run again. I have a new computer running Mach3 software with bran new stepper motors, breakout boards, and powersupplies.
The issue I am having is that my motors, no matter how I have them tuned, Fast, slow, or otherwise. will not run in program. They will slip, grind, or jump while in the middle of a movement. It is not a contant thing either. I have run a drilling program where everything was perfect for the first 200 or so holes, then BAM its off for one reason or another. How do I fix this issue.
I have 1.8°, 200 step, 7.8 amp motors, NEMA 32 with a driver set to 10 microsteps.
My steps per is approx 390 velocity 3048 and accelll about 250.
I use MM increments.
ANYHELP WILL DO, I AM AT MY WITS END WITH THIS THING!!!!!!!!
fixittt
Active Member
Offline
Re: Motor Tuning Help
Reply #1 on:
December 12, 2011, 04:37:44 PM »
what stepper drive are you running?
is the machine binding? twisting casing the motors to loose steps?
any change that the coupler between the motor shaft and the lead screws are slipping?
what kind of lead screws? acme screws with plastic backlash nuts? (I have had acme screws get worn in the center of the screw and anytime I tried to move outside of the worn section of the screw the backlash nut would stall the motor because it had adjusted itself to the worn smaller section and bound up when it tried to go over the larger non worn section.
cncalex
Active Member
Offline
Reply #2 on:
December 12, 2011, 04:42:05 PM »
Hi Airplane Guy,
your settings will result a screw lead of 5.128 mm
If the lead is 5mm you will have 400 steps per mm
your steps per unit must exactly match
Alex
Airplane Guy
Active Member
Offline
Reply #3 on:
December 12, 2011, 05:20:20 PM »
I am using an Mondostep 7.8 Bi-Polar Stepper Driver. I know the machine is not binding or twisted anywhere. I have leveled it, and re-built the gantry. So I know there is no mechanical issues. If I am thinking about this correctly, I don't have a lead screw, my table is cable driven.
Airplane Guy
Active Member
Offline
Reply #4 on:
December 12, 2011, 05:24:38 PM »
I am thinking its a pulse problem maybe, my time to int. stays at about 6.7 to 7.8 while running a program or not. Also, I have ran a pulse test. It tells me it is at excellent but if I were to move a small inner window, it will change to pulse too slow. How would I fix these issues?
cncalex
Active Member
Offline
Reply #5 on:
December 12, 2011, 05:48:56 PM »
I do not have much experience with pulsing problems.
Did you optimized your system for mach ?
try 25Khz kernel speed.
alex
pplug
Active Member
Offline
Reply #6 on:
December 13, 2011, 08:07:48 AM »
Try using a separate video card. The video card built on the motherboard can slow the CPU and create problems for mach. you could use one of the cheapest video cards out there and still get good results.
Airplane Guy
Active Member
Offline
Reply #7 on:
December 13, 2011, 09:09:41 AM »
I can't install a seperate video card, no room for on in the computer I have for it. I have optimized it to run only mach. I will give that a shot today.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
