Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 10:25:55 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
bench testing the parallel port and pins -questions and issues
Pages:
1
2
Go Down
« previous
next »
Author
Topic: bench testing the parallel port and pins -questions and issues (Read 431 times)
Active Member
Offline
Carnoustie, Scotland
Re: bench testing the parallel port and pins -questions and issues
Reply #10 on:
December 12, 2011, 04:10:27 AM »
Ok downloaded the JSR1 xml and although you dont have any ports and pins assigned for things such as axis it works fine here. What I mean by that is when I open it I can not reszet until I change the active state of the E-Stop input to Active Low as I dont have an E-Stop connected to that pin. There is obviously something weird going on with your computers, maybe you have some port monitoring software installed?
Active Member
Offline
Reply #11 on:
December 13, 2011, 06:18:08 AM »
Been thinking about this and I am wondering if you have the parallel port driver nstalled and you have it chosen when you start Mach?
If you dont then that would likely be the reason you can reset no matter the state of the E=Stop input. To see if the driver is working have a look on the Diagnostics page when in Mach and see if there is a frequency and Time in Int, I am guessing there is not.
JSRichards
Active Member
Offline
Reply #12 on:
December 13, 2011, 09:26:28 PM »
Hood Said: "see if there is a frequency and Time in Int, I am guessing there is not."
I dont undesrstand what you mean here. Please explain? Thanks!
R.
Active Member
Offline
Reply #13 on:
December 14, 2011, 03:00:31 AM »
Open Mach as usual then look on the diagnostics page and see if there is a frequency displayed or see if it says simulated. If its simulated then it means you are not using the Mach driver and that would likely cause the problems you are seeing. To use the Mach driver go to Function Configs menu and choose Reset Device Select and then restart Mach, you will get a box pop up asking if you want to use the Parallel Port, choose it and things will hopefully start working. If you dont get that option then its likely the driver is not installed, to install go to Mach3 folder (with Mach itself closed) and double click the drivertest.exe and let it run, that will install the driver.
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
