May 28, 2012, 10:25:39 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Threading Multiple Start
Pages: « 1 2   Go Down
Print
Author Topic: Threading Multiple Start  (Read 449 times)
Bob La Londe
Active Member
Offline Offline
View Profile
« Reply #10 on: December 10, 2011, 10:54:43 AM »
What obvious fubar am I am missing?
I am thinking that the gotcha will be timing even if you rotated the part 180 degrees.
I will admit that i never did any thread milling.
Actually cut and paste the helix and rotate it 180 degrees in CAM.  Rotate the primitive, not the part.
Using exact stop milling of course.
I did just now think of one problem with my helix approach.  I have to join a line to the bottom (and probably the top) so that the cutter is not engaged with the part when it tries to retract if it starts at the top, or gouges its way down if it starts at the bottom.
You calculate the thread height for 1/2 rev then add that to the starting point. Have done it several times for large threads. It will put the second start 180 deg out from the first.
Justa thought, (;-)TP
Makes sense.
Bob La Londe
Active Member
Offline Offline
View Profile
« Reply #11 on: December 10, 2011, 10:55:52 AM »
I'll shoot a video when I cut it and if it works I'll post it.
Bob La Londe
Active Member
Offline Offline
View Profile
« Reply #12 on: December 16, 2011, 06:42:54 PM »
http://youtu.be/BMoKvHjf32g
« Last Edit: December 16, 2011, 06:48:15 PM by Bob La Londe » Logged
Pages: « 1 2   Go Up
Print
Jump to:
