Hello Guest it is June 10, 2026, 01:21:47 PM
Author Topic: Galil DMC-4040 Anilam analog amps and DC servos  (Read 40625 times)
« on: December 09, 2011, 10:18:23 AM »
Hi guys, I’m sorry for the length.  Please read and help if you can.  Please tell me if this is the right place to post this as well.  It might be more of a general question.
I’m converting a Fryer MB11 bed mill with a dead Anilam 1100M control to Mach3.  I was considering updating it to Mach3 prior to it dying anyways.  Then it died unexpectantly and I was not able to map out the wiring and what makes it tick while it was working.   I’m reusing as much as possible.  So that means DC servos and Anilam’s amp boards.  I bought a Galil DMC-4040 Accerera motion control off of eBay.  The Galil is connected via Ethernet port to an almost new touchscreen computer running Windows 7 64bit. Basically a computer built onto the back of a monitor.   I’ve loaded the software and add-on and seem to have that worked out.  I might/probably need to do some configuring yet.  The limits and the encoders work.  I have what amounts to a manual mill with DRO.  I can’t “turn on” the servos then yet “move” them.     I don’t know what the conventional terms are, so… before the Anilam died when I reset the servos they would power up in a way that held the axis’s stationary.  I’m going to call that “turn on” IF after that, it received a movement command THEN it moved.  I’m going to call that “move” ” or “moving”.
The parts that were reused are a relay board, a power supply, three Anilam analog amp boards, and three Anilam 37000117 DC servos.  I know I have something wrong with the wiring and or the configuring and or the operation of Mach3.  The power supply is just a bridge rectifier (BR) connected to a big capacitor,  Two wires (115VAC) feeds the BR then two wires feed the capacitor and then out of the capacitor comes 12  thinner wires to feed the  amp boards.  Six wires come out of each of the two screws on the capacitor, two positive and two negative wires to each amp board.   All amps and motors are wired the same.   In addition to the DC “in” wires the amps each have four thin (2 of each) DC “out” wires going to the motors from the same amp wire plug/harness (J4).  Also there are five wires to the (J1) plug/harness.   Two thick wires (white and light green) go to the motor, two more (red and black) for what I think are the +-10VDC  that used to go to the Anilam motion control board that now go to the Galil.  The last wire (blue) is jumpered to all three amps and back to the relay board.  None of this wiring other than the two I think/hope are +-10VDC have changed.  There were no wires added or removed from the amp board or the servo.  A couple of wires from the relay board to the old Anilam motion control board were removed however.  This might be where my problem lies as well.  The blue wire that is in series to all three amps goes to ground unless the relay is powered up and its normally closed contact is opened.  The same 24VDC power that opens this contact also activates another relay which in turn sends the 115VAC to the bridge rectifier that feeds the amp.  This 24VDC for the relay is where I was planning to use a eStop switch.   When I supply power (115VAC) direct to the power supply (BR and capacitor) all three amp board’s error LED light up instantly.  When I supply power to the power supply and disconnect the ground that normally faults the amps (blue wire) on the amp board by applying 24VDC to the relay board something weird happens.  The output from the relay board which should be 115VAC as well as the DC into the amp board varies.  It gets so far and “resets”.  When nothing is connected the out  from the activated relay board is 115VAC.  When everything is connected the output is "reduced” to around 22VAC and then climbs to around 38.3VAC, ramping up fast at first and slowing down as it goes up.  When it reaches 38.3 it resets back to 22 and starts all over again.  It might go all the way to zero but it climbs real fast at first and the first readout on the meter I can read is 22VAC.  It’s the same thing on the DC side of the power supply only with DC.  At 38.3vDC  I see the fault LED on the amp card flash then it resets back to 22 (again it might go all the way to zero) and climbs back up to 38.3VDC and resets again.  Clearly, the fault is what is causing the reset.  Don't know why or what to do yet.  I also don't know if I have everything setup right in Mach3.  It doesn’t seem to be putting out any kind of signal.   On the wires that should be putting out +-10VDC.  Another very possible reason may just be my operation of Mach3.  I reset, hit the tab button bringing up the jog screen and hit the +X,Y,orZ.  It should move 1.0”.   Other buttons pressed after that say something like “can’t perform during move”.  The Galil has firmware 1.0A.  I did a master reset on it last night just to make sure the memory was clean.  Has anybody reused Anilam amp boards and DC servos and made theirs work?  How does one get the servos to “turn on”?  “Move”?  Is the output supposed to vary?  Any suggestions would be great.  I’ve run out of possible reasons.
Re: Galil DMC-4040 Anilam analog amps and DC servos
« Reply #1 on: December 10, 2011, 09:04:08 AM »
By any chance would PIN6 of the P3 connector on the PCB801 board be one of the wires that were removed?
Darek
« Reply #2 on: December 10, 2011, 11:45:57 AM »
I find it much easier to get the drives working by using the Galil Terminal program to enter Galil commands in order to 'talk' to the drives directly, if you have the machine schematics, it should be possible to easily check the power circuits.
Nosmo.
« Reply #3 on: December 10, 2011, 01:29:31 PM »
Darek,
The only pin I have connected on the P3 connector is the ground via a eStop switch.  On the relay board closest the corner is P1 with 2 pins, the P7 with 3 pins then the P3 connector.  I don't see any numbering on the card so the pin closest to the corner is what I'm calling pin 1.  Does pin 6 do anything?  I would have to test it but it looks like a ground wired there would "activate" the K4 relay.  Is there another wire that needs to go back to the Galil?
« Reply #4 on: December 10, 2011, 01:53:10 PM »
NosmoKing,
I don'y have the schematics.  Do you happen to have the schematics to Anilam's 31500966 amp boards?  There likely similar for diderent models so any model's schematic would probably help.  Darek sent me the schematics for the relay board and JH (JHChoppers) sent me some of his notes on a conversion he did.  On his notes his amps had pins 13 and 14 (J1 connector on anp boards) jumped together and mine are not.
« Reply #5 on: December 10, 2011, 03:09:00 PM »
Darek,
If I connect a ground to pin6 of P3 then all of P8 connectors switch (3 NO connections become closed and three NC connection become open) as well as a pins 4 & 5 of P4 close.  All pins on these connectors are currently not attached to anything.
« Reply #6 on: December 10, 2011, 03:20:39 PM »
PIN 6 of the P3 connector turns on the K4 relay which has as contact in the E-Stop loop. It was used to keep the drives from enabling untill the control was ready, it would also kill the drives if the control detected a problem.
Darek
« Reply #7 on: December 10, 2011, 04:43:55 PM »
Darek,
Whatever was connected between P8 (and/or P4) and the old motion control must still be needed.  The Galil must need some kind of a "it's ready" signal.  That's easy enough to arrange but to what pin on the Galil and what is the signal  (Ground, 3.3,5, 12, 24VDC, or connect two pins)?  At least know I have something to look for.  Looks like its time to read the manuals.  Thanks for the help.
« Reply #8 on: December 10, 2011, 05:31:22 PM »
Rereading your post, if your are grounding PIN 1 of P3 that should turn on the servo DC high voltage.
Darek
« Reply #9 on: December 10, 2011, 06:51:45 PM »
Darek,
 originally from you:
Amplifier J1 ( Motor Control )
1   NC
2   RED     ( * Axis Signal +/- 10 Volt DC [ From DSP Board ] )
3   WHITE   ( ? Tach FeedBack [ To Motor & Encoder Harness ] )
4   GREEN   ( ? Tach FeedBack [ To Motor & Encoder Harness ] )
5   NC
6   BLUE    ( * Servo Output Enable [ From eStop Relay Control Board ] )
7   NC
8   NC
9   NC
10  NC
11  BLACK   ( * Axis Common, Signal/Analog Ground [ From DSP Board ] )
13  JUMPER  ( * Connect to PIN 14 )
14  JUMPER  ( * Connect to PIN 13 )
It also removes the ground from from the amp's J1 pin 6 Blue and leaves the blue wire just floating.  I have nothing connected to the Galil's AENx (amp enable x=-A,B,or C).  I don't understand what it is.  Is it a signal passed from the Galil, or to it.  From or to what is the other end attached to?
