Hello
Guest
it is
June 11, 2026, 11:20:17 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Reversing slave axis going from leadscrew to R&P drive
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Reversing slave axis going from leadscrew to R&P drive (Read 10764 times)
watsonstudios
43
on:
November 29, 2011, 06:54:55 PM »
In My original MACH setup on my smaller CNC router, My X and A were slaved for my gantry and the steppers were connected to a lead screw system. Thus they were both spinning the same direction. I'm re-building my router to a larger size and now using a Rack & pinion system to drive the gantry. Now....The X & A motors will need to turn in the opposite direction because they will be mounted perpendicular to the X axis & facing each other, meaning they will need to turn in opposite directions to move the gantry in the same direction. My question is can I just reverse one of them in Mach or do I need to re-wire one of the motors in reverse?
Any advise appreciated. Thanks.
Carnoustie, Scotland
Re: Reversing slave axis going from leadscrew to R&P drive
Reply #1 on:
November 30, 2011, 07:43:08 AM »
Should just be a case of changing the axis state of the motor you wish to reverse.
watsonstudios
43
Reply #2 on:
December 02, 2011, 12:08:38 PM »
Ok, where do you do that in Mach? I can't find any setting or config that lets you reverse direction of axis.
Reply #3 on:
December 02, 2011, 12:12:43 PM »
Config, Ports and Pins, Motor Setup, the motors Direction will depend on whether you have Active Low chosen or not for the Dir. The other place you can reverse is Config, Homing and Limits.
watsonstudios
43
Reply #4 on:
December 02, 2011, 12:17:23 PM »
Yes, I think active low is selected for all motors. So do I just de-select active low for the A axis and that will reverse it?
Reply #5 on:
December 02, 2011, 12:18:53 PM »
Thats it
watsonstudios
43
Reply #6 on:
December 02, 2011, 12:24:34 PM »
Thanks! I actually did it in homing/limits and just reversed A - Worked perfect! Now does it matter what setting I use, or will it be the same whether using active low or reverse in homing/limits?
Reply #7 on:
December 02, 2011, 12:26:30 PM »
Doesnt make any difference at all
Print
Pages:
1
Go Up
« previous
next »
