Hello Guest it is June 11, 2026, 12:25:15 AM
Author Topic: wide screens with Mach  (Read 7251 times)
« on: November 27, 2011, 10:21:09 AM »
I've been thinking of replacing my old boxy class screen with a new wide flat screen. Will Mach screens work this this wide screen?
•Screen Size: 19"
•Widescreen: Yes
•Diagonal Size: 18.5"
•Pixel Pitch: 0.3mm
•Display Area: 410x230mm
•Display Colors: 16.7 million
•Display Format: 16:9 Widescreen LCD
•Vertical Refresh Rate: 55-75Hz
•Horizontal Frequency: 30-80kHz
•Interface Type: VGA
•Maximum Resolution: 1366 x 768
Tony
Re: wide screens with Mach
« Reply #1 on: November 27, 2011, 04:30:08 PM »
It will work but either the screen will be just part of the area of your screen or if you use AutoEnlarge it will look a bit stretched. The standard screens are designed for 1024 x 768
« Reply #2 on: November 28, 2011, 06:03:45 AM »
Thanks Hood,
I think I'll try it and play with different resolutions.
Tony
