Hello Guest it is June 11, 2026, 05:29:19 AM
Author Topic: Digitizing question  (Read 7072 times)
Offline dresda
  •  220 220
Digitizing question
« on: November 25, 2011, 07:19:22 PM »
So if I touch probe digitize using Mach and the wizard does it only give me the xyz data and or a G code of the finished part, and if so, how do I account for the raw stock that has to be removed or do I have to shift the profile down in the Z to the finished size.
The old way of digitizing models would be to scan the part with a sylus of the diameter of the cutter for roughing and keep reducing the sylus diameter and cutter for semi finish then finish.
Ray.
Re: Digitizing question
« Reply #1 on: November 25, 2011, 07:39:51 PM »
It just gives you the XYZ point data.
You'll need a program to convert that to a 3D model or mesh, and a CAM program to create g-code.
Try MachCloud on the downloads page to convert the points to an .stl file
Offline dresda
  •  220 220
« Reply #2 on: November 25, 2011, 08:49:25 PM »
Thanks.
Ray.
