Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 09:12:34 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Mach3 causing computer to restart.
Pages:
1
Go Down
« previous
next »
Author
Topic: Mach3 causing computer to restart. (Read 278 times)
bofee
Active Member
Offline
on:
November 23, 2011, 04:19:42 PM »
I'm just getting started with Mach3 on a CNC router build. I had basic functions working a couple of days ago with the Gecko G540 configuration installed. Today everytime I load Mach3 my computer reboots. I disconnected everything and reloaded the software, no help.
Anybody have suggestions?
Active Member
Offline
Carnoustie, Scotland
Re: Mach3 causing computer to restart.
Reply #1 on:
November 23, 2011, 06:32:02 PM »
What are the specs of the computer?
Check in the BIOS to see what temp and voltages are like.
bofee
Active Member
Offline
Reply #2 on:
November 23, 2011, 07:45:42 PM »
The computer is a 3Ghz Pentium 4, CPU is running at 25 Deg C. The hard drive is about 10% full and checks out clean for errors. Upon restart I'm getting a message,"System has recovered from a serious error." I can't even run the driver test app because the computer reboots when Mach3 takes over.
Active Member
Offline
Reply #3 on:
November 24, 2011, 02:51:51 AM »
Did you see what the voltages in the BIOS were like? Could be the power supply is failing or even the voltage regulation on the motherboard itself. Other things that may cause it could be a conflict between software such as maybe an anti virus, try disabling anything such as that and see if it helps.
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline
Reply #4 on:
November 24, 2011, 08:22:00 AM »
Have you tried all the Mach 3 optimization steps if you're running XP?
http://www.machsupport.com/downloads/XP_Optimization.txt
Dave->
bofee
Active Member
Offline
Reply #5 on:
November 24, 2011, 01:16:39 PM »
I will look at all the above. There is also a section in the manual (2.4 Installation Problems) that describes what I am seeing.
crazy council
Active Member
Offline
Reply #6 on:
November 25, 2011, 04:37:05 AM »
we have had this exact same problem, it was the processor overheating. ( after checking everything else ).
when your computer restarts, does it always reboot or does it sometimes have trouble rebooting
bofee
Active Member
Offline
Reply #7 on:
November 25, 2011, 11:51:30 AM »
Nope, no apparent problems on reboot.
crazy council
Active Member
Offline
Reply #8 on:
November 25, 2011, 12:09:20 PM »
I would not rely entery on the temp settings from your bios. There are very few things that shut a pc cpmpleatly down,
You have checked your chip for overheating.
Run a disk check, select the option that says look for bad sectors, ( it will ask you to shut down to run it )
Run a memopry test.
If your chips not overheating, will propbebly be your disk.
somtimes in the bios, it stors the last fault condition, ? make sure xp is updated as i think there is a upgrade for the chip driver if its a duel core chip
bofee
Active Member
Offline
Reply #9 on:
November 29, 2011, 04:04:34 PM »
I ended up re-installing Windows and Mach3 is running OK. I may never know the details of what was causing the computer to re-boot.
Thanks for everybody's help.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
