Hello Guest it is June 10, 2026, 09:15:53 AM
Author Topic: VFD and vari speed pulleys  (Read 22686 times)
Re: VFD and vari speed pulleys
« Reply #10 on: November 23, 2011, 01:47:24 PM »
I used a Marathon Black Max inverter duty motor, max safe speed 5400 but I never needed to run it over 4500.
It runs at full rated HP down to 30 rpm, the lowest I have needed to run it so far.
"It runs at full rated HP down to 30 rpm" - You mean "...full rated *torque* down to 30 rpm...".  To achieve full rated power would mean the torque was actually *increasing* as you reduced RPM - which would be a good trick.
« Reply #11 on: November 23, 2011, 06:08:22 PM »
Thanks for that correction Ray.
Russ
Offline bw
  •  29 29
« Reply #12 on: November 26, 2011, 07:06:26 AM »
I think I figured out what I would like to do but would like to run it buy here to see if I am missing something.
If  I go with a 6.75 pulley on the motor and 3.75 on the spindle, it will give me a 1:8 ratio with 3150 rpm at 60Hz and about 375 rpm in back gear.
At 120Hz I will have 6300 rpm
At the low end 10Hz, 525 rpm and 60 rpm in back gear.
Those numbers work or me as long as I am not missing something, also I can get a GS2 VFD from a friend who is no longer using it but it is not a sensorless vector unit and I am not sure if I should use it or just get a VFD that is sensorless vector.
Thoughts?
« Reply #13 on: November 26, 2011, 08:37:39 AM »
Your numbers are correct.  I would hold out for a sensorless vector drive, otherwise you won't get useful torque at anywhere near 10 Hertz - more like 30-40Hz, before the torque  becomes too little to be of much use without switching to backgear.
Offline bw
  •  29 29
« Reply #14 on: November 27, 2011, 08:42:35 AM »
From what I have been reading I figured the sensorless vector drive was the best choice, just wanted to be sure.
Offline bw
  •  29 29
« Reply #15 on: December 28, 2011, 08:05:52 AM »
I just wanted to thank everyone who helped me on this project.  I ended up replacing the spindle bearings as well as all the bearings that were left in the head after removing the vari speed pulleys.  I figured do it all when I had it apart.
The machine runs fantastic, sounds great and I now wish I did it a long time ago!  If I could just figure out how to get the auto zero to work with this Ajax system I would be done.  I posted on the Ajax forum but tech or anybody else has yet to answer and it's been several weeks.
