Hello Guest it is June 09, 2026, 10:41:41 AM
Author Topic: LPT2  (Read 21878 times)
LPT2
« on: November 18, 2011, 03:43:03 PM »
Can the flood and mist outputs be triggered from LPT2?
I would think under the outputs tab I can use;   Output 1  port 2 pin 17
That look right?
 I have a cnc4pc c15 relay board that I want to use for my solenoids.
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=24&products_id=148
I want to eliminate using LTP1 which is a Gecko540
Re: LPT2
« Reply #1 on: November 18, 2011, 04:08:35 PM »
Yes no problem with that at all.
Re: LPT2
« Reply #2 on: November 18, 2011, 04:25:01 PM »
I checked parallel port 2 and I am getting 3.3vdc when I hit the flood.  Problem is the C15 is not triggering the solenoid.   I am not sure where I should be getting the ground from for the C15.  Should I be getting off the parallel port?  The wiring instructions say the grounds are common.  No clue what that means.
http://cnc4pc.com/Tech_Docs/C15R2WG.pdf
I did call CNC4PC and the possible problem could be the relay is optoisolated and it may not work with a parallel port.  Although it seems to say to me it should work with a parallel port.
Re: LPT2
« Reply #3 on: November 18, 2011, 04:32:01 PM »
The ground I would imagine would have to be from the same source as your signal, are you getting the signal direct from the port or is it via a BOB?
Re: LPT2
« Reply #4 on: November 18, 2011, 04:41:28 PM »
Directly from the parallel port.
Re: LPT2
« Reply #5 on: November 18, 2011, 05:11:54 PM »
Reading the docs it would seem to suggest it should work from a parallel port.
Re: LPT2
« Reply #6 on: November 18, 2011, 05:40:56 PM »
I was told I bought the wrong board.  I need the C36.
Re: LPT2
« Reply #7 on: November 18, 2011, 06:09:42 PM »
Their website seems to say the C15 only works with 5V parallel ports, while the C36 works with 3.3V and 5V ports.
Re: LPT2
« Reply #8 on: November 18, 2011, 06:35:38 PM »
But the docs mention 3.3v which would make you think its fine.
Re: LPT2
« Reply #9 on: November 18, 2011, 07:35:35 PM »
Thats what I thought.
