Hello Guest it is June 10, 2026, 03:39:19 AM
Author Topic: Newbee needing some advice on v-carve circle coming out as an oval :-(  (Read 10019 times)
Hi all,
I am James, just got a secondhand cnc router working manually and I can also send v-carve generated .txt files to mach3 and they run and cut.
Problem is that all data seems to stretch in height (Y-axis). if I do a circle in v-carve software it comes out as an oval when cutting on the wood.
I do a 20mmx 20mm square it comes out as a rectangle.
When I did a sign which was imputed as a JOB SIZE 100 x 250mm in v-carve the letters when cut were central to the 250mm but not central to the 100 mm height.(positioned high)
Any ideas what is wrong and how I can correct it??
Any help will be greatly appreciated.
James
Re: Newbee needing some advice on v-carve circle coming out as an oval :-(
« Reply #1 on: November 18, 2011, 09:21:14 AM »
Hi James, welcome to the forum.
1. Have you checked/verified that the Steps per Unit are set up correctly in Motor Tuning ?
2. Is there any Scaling set in Mach ?
3. Is the Vectric SW a legal copy ?
Russ
« Reply #2 on: November 18, 2011, 12:38:22 PM »
Thanks Russ , I have found the axis calibration function on the settings tab and will let you know results.
The scale feature I have not found yet, where am I to look?
The copy is licensed so shouldn't be the cause of the problem.
Cheers,
James
« Reply #3 on: November 18, 2011, 04:12:33 PM »
Scale is at the side of each DRO on the main page, if its set to 1 that is ok.
« Reply #4 on: November 24, 2011, 05:17:37 AM »
Russell, Got the hang of calibrating the axis and now the circle comes out as a circle not a oval! Thanks for the tip.
Hood, Yes the scaling is 1 for all axis on the home page. Sorted on this one now. Cheers.
James
« Reply #5 on: November 25, 2011, 06:46:28 AM »
Happy for ya James.
Let the fun begin !
Russ
