Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 08:57:15 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
CAPAITIVE THC PLASMA PROBLEM
Pages:
1
Go Down
« previous
next »
Author
Topic: CAPAITIVE THC PLASMA PROBLEM (Read 317 times)
bdrotaru
Active Member
Offline
on:
November 16, 2011, 10:14:33 AM »
I have a problem with inputs to Mach3.
I have a height sensor (THC) in a plasma cutting machine that emits four signals:
Torch UP
Torch Down
Torch ON (given by a capacitive sensor which considers optimal cutting distance)
Probe (Touching the board)
Now ... Depending on the condition that the z axis is found to give an appropriate signal pin MACH3 attributed to the state and activity is 15VDC and inactive is approximately 3.2 VDC at about 100mA
The downside is that MACH don't read input state even though I tried both direct connection to the parallel port and breakout board.
Initially I thought that my parrallel port is broken but I checked the input port of MACH3 with Autodetect Inputs and both directly and through BOB works very well.
Can anyone tell me as to why I do not see the signal from the THC MACH3?
Sorry for my bad English
rrc1962
Active Member
Offline
Re: CAPAITIVE THC PLASMA PROBLEM
Reply #1 on:
November 16, 2011, 07:17:32 PM »
Sounds like you need to build an interface between your THC electronics and Mach3. The parallel port is not compatible with the 15VDC signal coming from your THC. Most breakout board will not be either.
bdrotaru
Active Member
Offline
Reply #2 on:
November 20, 2011, 08:17:49 AM »
I built an relay interface but sadly the relay are not fast enough. Can someone help me with this problem?
rrc1962
Active Member
Offline
Reply #3 on:
November 20, 2011, 11:13:30 AM »
Maybe use transistors instead of mechanical relays.
BR549
Active Member
Offline
Reply #4 on:
November 20, 2011, 11:38:23 AM »
Do you have a manual for the THC?
rrc1962
Active Member
Offline
Reply #5 on:
November 21, 2011, 02:54:27 PM »
Is it this one? This is supposed to work with Mach3, and it's not terribly expensive.
http://www.agelkom.com.tr/mach3.htm
bdrotaru
Active Member
Offline
Reply #6 on:
November 21, 2011, 03:00:40 PM »
yes. the exact one
rrc1962
Active Member
Offline
Reply #7 on:
November 21, 2011, 03:28:53 PM »
Did you contact the guy you bought it from? It's supposed to work with the Mach3 THC Up and Down inputs, which means you shouldn't be seeing 15VDC on any of the THC outputs.
KTM
Active Member
Offline
Reply #8 on:
November 26, 2011, 12:56:51 AM »
The Cap. THC has a very low current PWM output which is made for the H-Bridge to drive a DC motor more accurately.
I preferred the old THC which only had digital up/down signals.
I suggest you speak to Argun for a solution, or if it is possible to send the THC back, order the older version.
Regards
Steve
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
