Welcome, Guest. Please login or register.
Did you miss your activation email?
May 28, 2012, 10:15:46 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Bargain Basement
| | |-+  AC servo Motor and Drive 750W Mitsubishi Industrial J2S series - set up for MACH
Pages: 1   Go Down
Print
Author Topic: AC servo Motor and Drive 750W Mitsubishi Industrial J2S series - set up for MACH  (Read 486 times)
simpson36
Active Member
Offline Offline
View Profile
« on: November 14, 2011, 04:54:18 AM »
Very powerful AC servo motor and drive for sale. These drives have their own power supply built in and self-tune, so there is nothing else to buy and no tuning hassle. Interfacing these types of drives to Mach3 is not a trivial matter, but all of the special inteface boards (now fully opto isolated) and shielded wiring is included, ready to play and play with Mach. You just connect step/dir and e-stop to your BOB and start cutting. The drive runs on 220V single phase power. this is the largest Mistu you can run on single phase. For perspective, the 400 watt version of this setup outperforms Keling's largest NEMA34 DC brush servo driven by a 35AMP servo drive. The motor can produce 300% of its rated torque for short periods (ideal fot tapping).
This motor can power any normal axis, a 4th axis, a spindle, and is an ideal to power a lathe head. Goodby to threading problems with this setup. I am selling only becuase I want to move up to the J3 series drive and motor which has higher speed and smaller size (and larger price) to match the J3 setups on my new mill's X,Y and Z axis. I purchased the drive new and the motor used. Asking $800 for the set including all cables and connectors and Mach intefacing boards. If you need help adapting this to your machine, I can make mounts and/or custom timing pulleys for reasonable additional cost as part of the deal.
Currently powering custom 4th axis as seen here 1st example is brute force:
http://www.youtube.com/watch?v=yM06Ro7y_oU
Examples of high speed and hard tapping:
http://www.youtube.com/watch?v=xwrX-nh_YRI
And finally very high speed (about 3,000 RPM ) on the latest dynamically balanced 4th axis:
http://www.youtube.com/watch?v=HvjnDQoh-7I
« Last Edit: December 13, 2011, 06:02:54 PM by Overloaded » Logged
simpson36
Active Member
Offline Offline
View Profile
« Reply #1 on: November 22, 2011, 04:49:48 AM »
Will consider reasonable offers.
Logged
simpson36
Active Member
Offline Offline
View Profile
« Reply #2 on: December 13, 2011, 04:55:39 PM »
Moderator, please mark as sold. Thanks!
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
