Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 10:12:58 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Help with setup of driver and breakout board?
Pages:
1
Go Down
« previous
next »
Author
Topic: Help with setup of driver and breakout board? (Read 489 times)
pog
Active Member
Offline
on:
November 10, 2011, 09:37:48 AM »
Hello,
I've been searching for a whole day on how to do this with no luck.
I have 5 driver boards (DQ542MA) and a parellel breakout board (pictured, not sure of make etc)
What I cant work out is how I:
a) wire them up (50% know)
b) workout the ports ad pins settings for mach3.
Any help will be greatfully appreciated, any more info needed on these to help?
Pog
Tweakie.CNC
Active Member
Offline
Super Kitty.
Re: Help with setup of driver and breakout board?
Reply #1 on:
November 10, 2011, 11:52:39 AM »
Hi Pog, looking at your photos you have it wired wrong.
In Mach Config / Ports & Pins / Motor outputs set X step Pin#2, Dir Pin#3 ; Y step Pin#4, Dir Pin#5 ; Z step Pin#6, Dir Pin#7 and set these active low then on your breakout board P2 will be X axis Step and P3 will be X axis Direction and so on.
P2 (X step) will connect to your driver PUL- and P3 (X dir) will connect to your driver DIR- and so on.
Your breakout board needs it's own + 5Volt and GND supply connection.
As far as I can tell the controller enable is left unconnected as is PUL+5 and DIR+5
Make sure your steppers are connected correctly before trying anything out (incorrect connection of steppers can be fatal to the controller).
Hope this helps.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
pog
Active Member
Offline
Reply #2 on:
November 10, 2011, 01:52:58 PM »
Quote from: Tweakie.CNC on November 10, 2011, 11:52:39 AM
Hope this helps.
Thanks for your reply!
O.K so I have the PUL- connected to pin #2 and DIR- to pin #3 so thats right atleast.
Can the 5volt power supply come from one of the drivers?
I have DIR+ (+5V) connected to GND on the BOB and PUL+ (+5V) connected to +5v on the board. Is that correct?
theres ENBL+ (+5V) and ENBL- (ENB) with no connections on the driver.
In mach3 I have: step pin #2 dir pin #3 in motor out puts.
Output signals is where I get lost, I have no idea what I have to do there, what pins are they? port #1 but pin?..
Motors are wired correctly.
Sorry for all the questions, but thanks for the help
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #3 on:
November 11, 2011, 02:14:42 AM »
Hi Pog,
My opinion ........
No - you need a 5 Volt supply connected to +5 and GND on the BoB.
What DC voltage are you using for your drivers ??
No - these should be left unconnected.
This has yet to be established but leave unconnected for now.
Open Mach / Click on Config (in menu bar) / Click on Ports & Pins / Click on tab Motor Outputs / Enter Pin# here and select active low.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #4 on:
November 15, 2011, 07:18:20 AM »
Pog,
After some further reading up on these motor controllers I have discovered that the ENBL+ PUL+ and DIR+ should all be connected to + 5 Volts. The ENBL- can, I think, be left open circuit for testing purposes but if necessary, to enable test operation, connect this to GND.
pog
Active Member
Offline
Reply #5 on:
November 15, 2011, 09:13:34 AM »
Okay, i have 2 ideas on possible ways to connect these up.
Attatched is a wireing diagram i have found, which looks like what you have said above.
So first thing first i need a 5 volt charge to +5v and GND on the breakout board. Then wire them as they are in the following fiagram and see where that takes me.
They ahve told me the ENBL are for limit switches and leave them empty for now?
I am pretty sure this will work now, the motor outputs are pin #2 - #3 etc. with dir active low.
What about my output signals, what pin numbers are these?
I am fairly confident i will get these running soon, after 2 weeks on them
Cheers.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #6 on:
November 15, 2011, 11:54:45 AM »
Pog,
Setup Mach as shown here.
pog
Active Member
Offline
Reply #7 on:
November 16, 2011, 06:24:17 AM »
Thanks for that Tweakie!
O.k. We have the motors running.
Another snag. the velocity in motor tuning is set to 1000mm per minute, but when jogging the motors they are moving very slowly, maybe 100rpm, even though mach is reading that they are moving at 1000mm a min.
Steps per is set to 2000 so they should be turning much faster than this?
Anything that i'm doing wrong. Are the chips set wrong on the driver, all 8 are "off".
Cheers.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #8 on:
November 16, 2011, 07:16:56 AM »
Great news Pog, extremely pleased you have got your motors running and you are making progress
The motor tuning is related to many factors and rather than repeat stuff here it is best described in the Mach manual
http://www.machsupport.com/documentation.php
Calculate your steps per unit based on leadscrew pitch, set microsteps, motor steps and any gearing you may have - the velocity setting relates to your machine's resistance to motion and the acceleration relates to the mass of the moving parts with both of these settings usually found by trial and error. The velocity setting needs to be set some 20% or so below the maximum you can achieve in order to get reliable machine operation.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
