February 13, 2012, 01:32:40 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Quantum
| | |-+  Quantum - The next generation
Pages: « 1 2 3 4 5 6 7 8 9 10   Go Down
Print
Author Topic: Quantum - The next generation  (Read 37972 times)
lemo
Active Member
Offline Offline
View Profile WWW
« Reply #90 on: June 01, 2009, 06:33:57 AM »
That's the setting which does not work. I can set any angle, and mach3 is ignoring the corners it should do in a full stop fashion. I use the SmoothStepper. Maybe that's related as the SS introduces a few more restrictions as well...
Cut five times and still to short...
MachineMaster
Active Member
Offline Offline
View Profile
« Reply #91 on: August 10, 2011, 12:11:05 PM »
Instead of using CV settings to do the exact stop on those corners, use G61 for exact stop then G64 after the corner to turn CV back on.
Pages: « 1 2 3 4 5 6 7 8 9 10   Go Up
Print
Jump to:
