May 28, 2012, 10:08:37 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Machscreen Screen Designer (Moderator: Klaus1311)
| | | |-+  Trigger Screen LED
Pages: 1   Go Down
Print
Author Topic: Trigger Screen LED  (Read 241 times)
Picengraver
Active Member
Offline Offline
View Profile
« on: November 07, 2011, 05:44:15 PM »
I have a small machine using a laser diode for wood burning.  For safety reasons, I have the machine fully enclosed in a box when running.  I trigger the laser diode using the C axis direction pin.
I have designed a custom screen for this machine, and I would like to have an on-screen LED light up (or change color) when the diode is triggered on by gcode.
So far I can not get an LED to light in sync with the diode.  Is it possible?
Thank You,
John Champlain
www.picengrave.com
Picengraver
Active Member
Offline Offline
View Profile
« Reply #1 on: November 21, 2011, 05:28:31 PM »
Replying to my own post - may help someone else.
I got it working - using a simple brain routine.  What a powerful feature!
Thanks ArtSoft and Art.
John Champlain
www.picengrave.net
Pages: 1   Go Up
Print
Jump to:
