Hello Guest it is June 09, 2026, 11:58:47 AM
Author Topic: Wacky axis movement  (Read 17200 times)
  •  9,356 9,356
Re: Wacky axis movement
« Reply #10 on: November 06, 2011, 01:54:51 AM »
Don,
If your motor tuning is in mm (and it is correct) then just convert the metric entries to inch units (eg. 320 steps / 25.4 = 12.5984 steps) and so on for Vel. and Acc. - remember to save each axis settings before proceeding to next axis. Also make sure Config. / Select Native Units is set to inches. Then test it thoroughly and if necessary make any small adjustments to Vel. and Acc. to obtain the best, 100% reliable, performance.
« Reply #11 on: November 06, 2011, 08:04:08 AM »
Thanks Tweakie
  •  9,356 9,356
« Reply #12 on: November 06, 2011, 11:14:54 AM »
My pleasure sir  ;)
