Hello Guest it is June 12, 2026, 11:55:26 PM
Author Topic: Wacky axis movement  (Read 17276 times)
Wacky axis movement
« on: November 04, 2011, 11:28:45 PM »
I fire up my router and do a ref all everything appears normal.
I jog an axis one inch and the spindle moves one inch.
BUT, if I load a file then all three DROs move to a seemingly random location.  If I then move the spindle 1 or 2 inches the DRO only moves by some small amount, say .06 or something.
So if I try to move the Z axis 4 or 5 inches the Z hits the stop long before the Z axis DRO gets to 0.75in.
Anyone have any clues??
Don
  •  9,356 9,356
Re: Wacky axis movement
« Reply #1 on: November 05, 2011, 02:37:34 AM »
Have you checked your native units are set to inches (assuming you are working in inches) ??
Is the GCode file you are loading using inch units ??
« Reply #2 on: November 05, 2011, 08:03:10 AM »
Yes. That is one of the first things I thought of too.  But, the movement of the DRO has no relation to the movement of an axis.
Inches or MM makes no difference
Thanks for looking,
Don
  •  9,356 9,356
« Reply #3 on: November 05, 2011, 08:50:24 AM »
Don,
What file are you loading ??
Does this happen with any file ??
« Reply #4 on: November 05, 2011, 10:45:34 AM »
This sounds like your native units are mm and your loading a file with G20 in it.
« Reply #5 on: November 05, 2011, 11:37:27 AM »
Units don't matter. The movement of the DRO doesn't relate to the movement of the spindle.  Large movement of the spindle small change in DRO.
I tried a couple different files with same result.
Don
« Reply #6 on: November 05, 2011, 11:56:31 AM »
Does your g-code have a G21 in it? I'm pretty sure it's a units issue. Probably opposite what I said before. Machine set up in inches, and running a file in mm's.
« Reply #7 on: November 05, 2011, 01:27:07 PM »
Gerry I have G20 in my Mach init string.
How do I check my native units?  This is a new machine (K2CNC).  The only software I received was the Mach profile.
« Reply #8 on: November 05, 2011, 01:29:24 PM »
Never mind I found it in motor tuning.
« Reply #9 on: November 05, 2011, 08:57:43 PM »
Gerry you and Tweakie are right!
My machine was motor tune in MM... If I put a G21 in my code I can run my files:)
What do I need to be aware of to change the motor tuning to inches??
Thanks for your quick help!
Don
