May 28, 2012, 10:04:14 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  Pokey matrix keyboard problem
Pages: 1   Go Down
Print
Author Topic: Pokey matrix keyboard problem  (Read 532 times)
leozalewski
Active Member
Offline Offline
View Profile
« on: November 04, 2011, 04:18:31 PM »
Hi
Setup a matrix keyboard 5 * 7. That part was easy, it worked for a while but then stared getting "Unhandled  exception" errors every time I try to open "Peripherals" then open up the keyboard configuration screen. The jpg is the error I get any suggestions to fix the problem?
Regards
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #1 on: November 04, 2011, 06:33:21 PM »
File 86 it......
Smiley
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
NeoTO
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: November 05, 2011, 05:40:13 AM »
Save configuration to a file and send it to support@poscope.com.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Pages: 1   Go Up
Print
Jump to:
