Hello
Guest
it is
June 11, 2026, 08:51:16 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Quick tool change question :)
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Quick tool change question :) (Read 9572 times)
Aeroshade
141
on:
November 03, 2011, 04:00:55 PM »
Hello all. I have a 24 pocket tool changer that works GREAT, the only problem is my orientate sensor for the spindle crapped out on me. I need to make the machine work by putting the tools in by hand. Do I need to change the "Tool Change" in "General Config" to "Stop Spindle. Wait for Cycle Start"? Will this bypass my m6start macro?
Aero
Carnoustie, Scotland
Re: Quick tool change question :)
Reply #1 on:
November 03, 2011, 04:11:01 PM »
Yes that should just do as it says, stop and wait for start.
BR549
6,965
Reply #2 on:
November 03, 2011, 04:15:44 PM »
I don't think it will bypass the M6start it just waites for a MANUAL cycle start to run.
ger21
6,295
Reply #3 on:
November 03, 2011, 04:58:12 PM »
When Set to "Stop Spindle, Wait for Cycle Start", Mach3 runs the M6Start first, then stops and waits for Cycle Start, then runs M6End.
Reply #4 on:
November 03, 2011, 05:04:04 PM »
Yes just tested and it does indeed. Easy solution, rename your M6 macros and replace with standard ones until you get the orientation sorted.
Aeroshade
141
Reply #5 on:
November 04, 2011, 11:11:18 AM »
Worked perfect!! Thanks guys
Aero
Print
Pages:
1
Go Up
« previous
next »
