May 28, 2012, 10:02:50 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  lost jogging with keyboard
Pages: 1   Go Down
Print
Author Topic: lost jogging with keyboard  (Read 164 times)
paulcscheung
Active Member
Offline Offline
View Profile
« on: November 02, 2011, 11:02:01 PM »
Hi all.
I have been using Mach3 for 2 years now, I have no problem at all until yesterday. I am unable to jog the touch head with key board left, right, up and down key, but it works fine with flys-out jogging control.
Anybody have suggestion on how to fix this other then doing a Mach3 re-install?
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: November 03, 2011, 02:19:58 AM »
Sounds like your Jog Control is switched off, see pic. If its on then it will show a green area around it.
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline Offline
View Profile
« Reply #2 on: November 03, 2011, 04:07:35 AM »
Another thought in addition to Hood above, if you're using a different screen or screen set, you must have a jog on/off button on any screen that you'd like to use the keyboard to jog with.
Dave->    Wink
Pages: 1   Go Up
Print
Jump to:
