Hello Guest it is June 11, 2026, 05:47:56 AM
Author Topic: Feed rate override switch  (Read 10005 times)
« on: October 26, 2011, 11:32:24 AM »
Hello all, I have searched for an answer to this for awhile and have come up empty.
I have posted this in both Brains and VB to get both opinions.
I have a 16 position binary switch ( 4 pins - 1,2,4,8). I have the pins set to Input #1,2,3 and 4. The way this switch works is pin 1 = 1, pin 2 = 2, pin 1 and pin 2 = 3 and so on tell you get 16 (counting all pins off as a position).
I need to find a way to have this control my feedrate over ride, plus my rapid override at the same time. I'm not sure if the best way would be with a Brain or in VB - Macropump. The most important thing is that the switch works fast.
I don't have a problem writing it up in my Macropump, just need a little guidance on the code.
This is what I was think for the layout, just not sure about the DRO for the FRO:
If IsActive(INPUT1) = False And
IsActive(INPUT2) = False And
IsActive(INPUT3) = False
IsActive(INPUT4) = False Then
SetOEMDRO(0, 0) <--- Needs to set the DRO to 0%
End If
If IsActive(INPUT1) And
SetOEMDRO(0, 0) <--- Needs to set the DRO to 10%
End If
So on and so forth, tell I get all 16 positions set.
Any help would be GREAT!! :)
Aero
« Last Edit: October 26, 2011, 11:36:13 AM by Aeroshade »
Re: Feed rate override switch
« Reply #1 on: October 27, 2011, 12:17:50 PM »
« Reply #2 on: October 27, 2011, 01:01:05 PM »
SOmething along these lines may work. This would be only 1 rung on the ladder for ALL 6 switches off then it sets the DRO to 0.0000
« Reply #3 on: October 27, 2011, 03:58:30 PM »
I tried that, but for some reason for it reads the largest %. This is how I set it up:
input 1 - invert
input 2 - invert
                              and - formula=0 - OEMDRO 821
input 3 - invert
input 4 - invert
input 1 - pass
input 2 - invert
                              and - formula=10 - OEMDRO 821
input 3 - invert
input 4 - invert
input 1 - invert
input 2 - pass
                              and - formula=20 - OEMDRO 821
input 3 - invert
input 4 - invert
input 1 - pass
input 2 - pass
                              and - formula=30 - OEMDRO 821
input 3 - invert
input 4 - invert
When I enable it, it sets my FRO DRO to 30%, and no matter what I switch it to it stays at 30%.
HELP :)
Aero
« Reply #4 on: October 27, 2011, 05:31:55 PM »
Then your inputs are not match to the brain correctly. IF they were then only the combinations of inputs it saw would activate the output. Try it with a value not just the pass /invert method.
Did you RUN the brain to test the output values based on the inputs. I normall y test each rung as I build it to VERIFY it is working correctly. THEN rebuild the tree with all the rungs.
