May 28, 2012, 08:51:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Problems with Measurements when cutting with MACH 3
Pages: 1   Go Down
Print
Author Topic: Problems with Measurements when cutting with MACH 3  (Read 220 times)
dodiano
Active Member
Offline Offline
View Profile
« on: October 23, 2011, 06:33:40 PM »
Hi Guys,
I use Autocad for my drawings and save them in DFX and convert them with Lazycam! Now I have been having toruble with measurements ... Normally one side is always off not sure why? For example I cutted a rectangle out of Acrylic which measured 2 Inches in Width x 10.75 in height! The 2 inches came out perfectly cut but the 10.75 inches measured like 10.85 and I have no idea why?Huh I seem to have this problem with certain drawings in Autocad but not all... Any ideas... Also another issue I have...
I make 1 piece which is a Left side for a project which has a hole on one side... I then use the mirror function in Autocad and mirror that same piece so I can have the hole as a right side for my project... Th thing is that when I convert the DXF file from Autocad mirrored and I convert it to Mach3 and then cut the part out the Hole piece is like 1/16th smaller ... Any ideas why??
Thanks for the help!
Roberto
Global Moderator
Offline Offline
View Profile
« Reply #1 on: October 23, 2011, 07:24:42 PM »
Post the dxf file and also the gcode file from LC.
Post the dxf file before mirroring it and also the dxf files for both sides.
How much backlash do you have on each axis?
I really don't think it's a Autocad or LC problem.
BR549
Active Member
Offline Offline
View Profile
« Reply #2 on: October 23, 2011, 07:35:34 PM »
Double check your acad draw for errors. Check all Dims
Double check your Gcode output from Lcam , Do the math verify the cut sizes are correct in the Gcode
Finally IF those 2 check out it only leaves the machine. Check the couplings and check for lost steps on the axis.
Just a thought, (;-) TP
dodiano
Active Member
Offline Offline
View Profile
« Reply #3 on: October 23, 2011, 11:35:51 PM »
Will check my dimensions and will do the maths on the G-CODE thanks for that! And if not is my CNC machine is just weird cause there are certain files I cut first cut is great second on is like 1/32 smaller ?? But just certain files specially those I have mirrored? Will post codes tomorrow!
Roberto
Pages: 1   Go Up
Print
Jump to:
