May 28, 2012, 08:51:18 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  drives will not reverse
Pages: 1   Go Down
Print
Author Topic: drives will not reverse  (Read 293 times)
engineeron
Active Member
Offline Offline
View Profile
« on: October 23, 2011, 12:45:30 PM »
I can jog in one direction only.  I replaced the BOB (DB25) recently and i also replaced my computer because the mother board was fried..  The Y  would reverse for a while   but when I made some changes it will work only one way now.  All seems ok in the program but may not be.  Help  Help
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: October 23, 2011, 02:00:59 PM »
Either bad wiring  for the Dir pins, bad bob  or you do not have the correct pins or ports assigned for the Dir pins.
engineeron
Active Member
Offline Offline
View Profile
« Reply #2 on: October 23, 2011, 05:02:27 PM »
I have all axis working in both directions Now ..except the X  axis.     I have checked and rechecked ports and pins setup  and  all checked to specs.  I was wondering if one wire is wrong on the bob. It maybe something simple.  Help
Active Member
Offline Offline
View Profile
« Reply #3 on: October 24, 2011, 02:05:31 AM »
If you have a spare output on the BOB rewire the X Dir to it and re-assign in Ports and Pins, Motor Outputs to that pin and see if it helps.
engineeron
Active Member
Offline Offline
View Profile
« Reply #4 on: October 24, 2011, 02:42:27 PM »
Thanks for the help... It worked.  I changed the wires on BOB for the X dr.  from  2 and 3   to  8 and 9 Smiley
Active Member
Offline Offline
View Profile
« Reply #5 on: October 24, 2011, 03:30:46 PM »
Smiley good you got it Smiley
Pages: 1   Go Up
Print
Jump to:
