Hello Guest it is June 12, 2026, 06:37:06 PM
Author Topic: tool not clearing top  (Read 26656 times)
Re: tool not clearing top
« Reply #20 on: October 24, 2011, 02:53:32 PM »
Reduce the accelleration on xy as well. Sounds like you are loosing steps on them as well.
« Reply #21 on: October 24, 2011, 02:55:33 PM »
Help / About ....  for the version.
« Reply #22 on: October 24, 2011, 03:15:39 PM »
ok, version is vr3.042.038
x was 31,31
y was 100,40
I changed the motor tuning on both to 31,20 now
I will reload a rod in the morning and see if that helps, of course y wasn't running anyhow, but x was and I reduced the acceleration on that by 1/3
« Reply #23 on: October 24, 2011, 05:55:36 PM »
Manufacturer says speeds for x,y,z are 1500 and 200.  I'm sure that's metric. So the speeds should be 59 and 7.5 in standard. That's quite different from what I had. I will try this in the morning and see if it fixes things.  A is correct, I know that as it's at the manufacturer recommended settings and in degrees.  Say a prayer for me! lol
« Reply #24 on: October 25, 2011, 07:58:25 AM »
Wow...now, 99% sure this looks like a victory dance!  I have x,y,z at 58 and 7.5 in motor control.  Lap 2 is cutting and appears to be dead on target and all pocket jumps have 100% cleared the work piece! I suppose the summary is that the motor tuning was way too high causing missed steps.
« Reply #25 on: October 25, 2011, 09:10:16 AM »
Good Job(;-)
