Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 08:50:24 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
An other "Auto Tool Zero" question.
Pages:
1
Go Down
« previous
next »
Author
Topic: An other "Auto Tool Zero" question. (Read 438 times)
gene8522
Active Member
Offline
on:
October 21, 2011, 07:07:19 PM »
When I press Auto Tool Zero my Z moves up, not down like it should.
This is the VB Code I have used for some time, but it has stopped working.
Message( "Auto Zeroing..." )
If IsSuchSignal (22) Then
code "G31 Z-3 F20"
While IsMoving()
Wend
Call SetDRO( 2, .060 )
code "G1 Z1"
End If
I have checked all the wiring, probe plate and settings so many time, that now I am getting confused about what I've checked and not checked.
Greolt
Global Moderator
Offline
Re: An other "Auto Tool Zero" question.
Reply #1 on:
October 21, 2011, 08:00:01 PM »
The code relies on the Z axis being above -3 when started.
If for example the Z DRO read -4 when starting the code, it would travel up to -3. Perhaps this is what you are seeing.
If that was the case then adding some lines like this could help
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Sleep 100 'Pause for Dro to update.
Code "G90 G31 Z-3 F20"
Greg
ger21
Global Moderator
Online
Reply #2 on:
October 21, 2011, 08:02:32 PM »
Also, if noise triggers your probe input, it will move to Z1, thinking it's finished. If it stops at Z=1, then it's possibly noise.
http://home.comcast.net/~cncwoodworker/2010.html
gene8522
Active Member
Offline
Reply #3 on:
October 21, 2011, 08:19:50 PM »
Quote from: ger21 on October 21, 2011, 08:02:32 PM
I have noticed on the "Diagnostics" page that the probe LED does flash, for no apparent reason. Do you know any reasons for the noise. I have been through the wires more than once. I may try to run temporary wires to the probe plate. But it will have to wait..............I have been at this sense 5:30am.
HimyKabibble
V4 Screen Contributor
Offline
Reply #4 on:
October 21, 2011, 09:09:29 PM »
Try adding a pull-up resistor (300 ohms or so) to +5V to the probe input.
gene8522
Active Member
Offline
Reply #5 on:
October 21, 2011, 09:51:20 PM »
Quote from: HimyKabibble on October 21, 2011, 09:09:29 PM
Thanks Ray I'll try the resistor.............. I knew someone would be able to help me here on the forum..................
ger21
Global Moderator
Online
Reply #6 on:
October 21, 2011, 10:26:32 PM »
A lot of people add a .1uf or .01uf capacitor across the input pin
gene8522
Active Member
Offline
Reply #7 on:
October 22, 2011, 07:34:37 AM »
I did notice that the Z moves up about an inch and stops. So I'm sure this is probable the problem.
The last time I used the CNC, about a month ago, it would not Auto Z Zero but I didn't have time to check for a reason. I had been using Auto Z Zero for months with out any troubles.
The problem came up again when I was trying to install "Mach3 2010 Screenset" I could not get Auto Z Zero to work with the 2010 screenset. Even though I chased the cause for hours. I was sure I must have some setting set wrong. Finely changed back to Mach3 screenset looking for help. But I could not get "Auto Z Zero" working. ( Must be a setting in the program, right?) I finely game to the forum for help, I new someone here would be able to help.......
ger21
Global Moderator
Online
Reply #8 on:
October 22, 2011, 12:17:31 PM »
If you have issues with the 2010 screenset, shoot me an email, or PM, or just ask in the forum threads (links at the bottom of my web page). I could have pointed you in the right direction pretty quickly. Noise is a fairly common occurrence, and other than bad Mach3 versions, noise is usually the only reason that the Auto Zero doesn't work.
gene8522
Active Member
Offline
Reply #9 on:
October 22, 2011, 10:50:17 PM »
I took ger21's advice and stopped at Fry's on the way home from work and picked up a .1uf capacitor and added it to the wires leading to the Z probe plate. The probe light on the "Diagnostics" page stopped flashing and the Auto Z Zero works like it should. Thanks to all for your replies. Now I can get back to installing Mach3 2010 screenset.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
