May 28, 2012, 08:47:18 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Feature Requests
| | |-+  Parametric Programming
Pages: « 1 2   Go Down
Print
Author Topic: Parametric Programming  (Read 4454 times)
Darc
Active Member
Offline Offline
View Profile
« Reply #10 on: January 16, 2007, 09:48:03 PM »
Thanks Fernando, I think I've got the idea now.
Just one thing, when I select "Edit Button Script", then select the button, I entered the code saved it as 03mm.ms1.
How do I tell the button to keep using that script, everytime I open the script for that button it is blank???
Not sure what I'm doing wrong.
Thanks again.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #11 on: January 16, 2007, 09:54:00 PM »
Can you do the script in Screen Designer 4 and save your screen set?
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
fer_mayrl
Global Moderator
Offline Offline
View Profile
« Reply #12 on: January 16, 2007, 10:28:42 PM »
Darc,
just save the code, dont save it as something else, that should work
Regards
Fernando
Darc
Active Member
Offline Offline
View Profile
« Reply #13 on: January 17, 2007, 04:29:39 AM »
Thanks Fernando you are the MAN, it works a treat......
fer_mayrl
Global Moderator
Offline Offline
View Profile
« Reply #14 on: January 17, 2007, 12:28:54 PM »
Not a problem, thats what we are here for.
Just glad I can give smething back to our comunity
Fernando
Darc
Active Member
Offline Offline
View Profile
« Reply #15 on: January 21, 2007, 02:44:42 AM »
Just out of curiosity, is it possible to have the toolpath preview window display the program that is run after you depress the button.
Also is it possible to have a single sblock button, I tried one and it didn't work (single step).
Thanks.
« Last Edit: January 21, 2007, 04:23:53 AM by Darc » Logged
fer_mayrl
Global Moderator
Offline Offline
View Profile
« Reply #16 on: January 21, 2007, 03:23:43 PM »
in order to be able to have a toopath window, and be able to single step, you will need to add a button to post the code directyl on the mach3 window, look at other wizards that have the post code button to learn how to do that. I dont know for sure how to do that, but looking at ready made wizards will help you for sure.
Regards
Fernando
LarryL
Active Member
Offline Offline
View Profile
« Reply #17 on: September 28, 2010, 03:32:10 AM »
Hi guys,
I am new to this particular forum, being the developer of the CNC Quilting Machine.  I am looking for some code that will assist me in determining the number of repetitions that I can sew into a given area.  Given, only two axis are used, x=length and y=width.  where y will be constant at approx. 6-8 inches, x can be as short as 10 inches or as long as 70 inches.  What I would like to do is be able to input the size of the pattern, i.e., 8"x7" and return the number of repititions that will fit in the x length.  Simple division, but I am not a whiz with math.  Help!!!!
Larry
Pages: « 1 2   Go Up
Print
Jump to:
