Hello
Guest
it is
June 09, 2026, 04:35:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
A problem writing macros
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: A problem writing macros (Read 8593 times)
drbricolage
7
on:
October 20, 2011, 10:09:38 AM »
I am trying to convert my mill with Mach3 and I've run into a bit of a problem. I want to toggle an output bit to control a solenoid to lock my Z axis. I wrote two macros ( M64 and M65) as follows:
M64
ActivateSignal(output4)
and M65
DeactivateSignal(output4)
I set up the output to connect to the right pin and put these in my profile macro folder as M64.mls and M65.mls. I can't see that there is anything else to do but when I try these under MSI nothing happens. What am I doing wrong? I would be very grateful for some help.
Overloaded
4,923
Re: A problem writing macros
Reply #1 on:
October 20, 2011, 10:22:17 AM »
Try .m1s for the extension.
Also, I think you shold use macros over 100 as many below are used internally. (from memory, which is weak).
drbricolage
7
Reply #2 on:
October 20, 2011, 10:30:22 AM »
Fantastic, it works! I just couldn't see where I was going wrong. Many many thanks.
Carnoustie, Scotland
Reply #3 on:
October 20, 2011, 10:33:04 AM »
Also worth mentioning you should really be using M101 and higher for custom M codes, under 100 are meant to be reserved for Mach internally.
Print
Pages:
1
Go Up
« previous
next »
