Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 08:46:07 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Jogging question
Pages:
1
Go Down
« previous
next »
Author
Topic: Jogging question (Read 275 times)
TunerTom
Active Member
Offline
Jogging question
on:
October 19, 2011, 03:21:57 PM »
I installed Mach3 (turn profile), complete with the license file in a newer "XP" box to replace an older system which has become inreliable. I have been busy entering "ports & Pins" data as well as motor tuning, etc... from written notes written down from an earlier installation.
I have a new "situation" I have never seen before. My hope is that this condition is an obvoius one that others have seen before...
First of all, the main working screen the Axis Position DROs cannot be "zero-ed" by clicking on either [Zero] button. Furthermore, even though I can click on the display boxes and they will highlight slightly, I cannot overtype the values in either DRO.
Fast & slow JOG functions works using the cursor keys, and the "X" & "Z" DROS will increment/decrement as expected, also the toolpost moves as expected
When I engage Jog Mode to "Jog Inc" (single-step) the stepper motors do not move and the DROs do not change value.
It is nearly impossible to properly place the cutting tool at the correct starting point and have the DROs reflect the proper coordinates.
Any suggestions from anyone? (I have attached a screen shot on the primary screen)
Last Edit: October 19, 2011, 03:27:20 PM by TunerTom
Active Member
Offline
Carnoustie, Scotland
Re: Jogging question
Reply #1 on:
October 19, 2011, 03:29:16 PM »
Can you attach your xml, that will be the easiest way to hopefully find the problem.
TunerTom
Active Member
Offline
Reply #2 on:
October 19, 2011, 03:33:14 PM »
It'a at work. I will get it tomorrow & bring it home. I will sent it as soon as I can...
Thanks, in advance...
Active Member
Offline
Reply #3 on:
October 19, 2011, 03:37:17 PM »
Ok, will wait for that but in the mean time make sure you are not in machine coords as that would make you think you can not zero the DROs.
TunerTom
Active Member
Offline
Reply #4 on:
October 19, 2011, 03:42:41 PM »
I'll look for that in the morning.
Will advise upon my return,
Thanks.
TunerTom
Active Member
Offline
Reply #5 on:
October 20, 2011, 07:54:04 AM »
OK, I discovered that the XML file was completely corrupted. The file was hardly readable... so I started over from scratch and replaced my User Profile from scratch, once again. Now the single-step function works properly, but there is a new problem...
On the X-Axis, Fast Jog, Slow Jog, and Single-step all work just fine in both directions.
On the Z-Axis, Fast Jog, Slow Jog, and Single-step all work, but no matter which (left/right) cursor key you operate, the toolpost will move only towards the left. Same holds true if you type on G-code on the command line... The tool post only moves toward the left, no matter what the instruction states. The only way I can bring the tool post back to the right is to turn the stepper-motors off and "hand-crank" the Lead Screw.
I am enclosng my XML file, in case that might help.
MyLathe.xml
(99.1 KB - downloaded 13 times.)
Overloaded
Global Moderator
Offline
Reply #6 on:
October 20, 2011, 08:09:57 AM »
You might double check the integrity of the connections of the DIR conductors.
The SW might be changing state but not physically getting through to the drive.
Just something to look for.
Russ
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
TunerTom
Active Member
Offline
Reply #7 on:
October 20, 2011, 08:22:08 AM »
OMG, How could I be so dumb?
The DIR lead for the Z-Motor , where it attaches to the Parallel interface card was loose.
How could I be so dumb??
Thanks everyone for your help.
Case closed.
Overloaded
Global Moderator
Offline
Reply #8 on:
October 20, 2011, 10:00:32 AM »
I wouldn't say "dumb", very easily overlooked.
Just glad it was something simple ..... or I would likely have been of no help.
Russ
Abe Lincoln
Active Member
Offline
Reply #9 on:
October 20, 2011, 10:34:07 AM »
Definitely not Dumb, these things happen and there are so many variables things get overlooked.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
