Hello Guest it is June 13, 2026, 02:26:49 AM
Author Topic: button to jog x and y  (Read 9203 times)
Offline Bill_O
  •  611 611
« on: October 19, 2011, 08:38:15 AM »
I want to make a button on my pendant that jogs both the x and y simultaneously.
Can I do this in vb script?
Maybe something like;
DoOEMButton(307)
DoOEMButton(309)
Bill
  •  9,356 9,356
Re: button to jog x and y
« Reply #1 on: October 20, 2011, 07:45:20 AM »
Certainly a good question Bill, i would like to know the answer to this one as well  :)
« Reply #2 on: October 20, 2011, 07:59:22 AM »
OK, So no one is going to bail you out(;-)
It is a yes and no question. Yes it can be done but not directly, you have to go all the way around the block to get it done. You have to use the LPT inputs for those functions and then use a brain to activate deactivate them as a pair.
That I know of it cannot be done directly from the screen. You Can from a plugin .
IF you do a search on the Yahoo site you will find references to the process.
Offline Bill_O
  •  611 611
« Reply #3 on: October 20, 2011, 08:18:50 AM »
thanks for the replys
i am using a pokeys so for a pendant so i can not use the brain
i will work on it some and see if i can find a way around it
