Hello Guest it is June 11, 2026, 01:45:09 PM
Author Topic: WTF old copy of Mach3  (Read 6416 times)
« on: October 18, 2011, 07:26:41 PM »
I had an old copy of mach3 hooked up to the CNC and it was working fine on jog. But it would only run about 20k lines of code.
I tried to update Mach3 but it did the same thing. Next I uninstalled Mach3 and reinstalled the software, installed the license for mach3, Set all the pins for the motors
now it want even Jog Mach3 software on the screen says that the unit is moving but the CNC does not move ????..........but now Mach3 sees all the G Code
Has anyone got any ideas
Trell
Re: WTF old copy of Mach3
« Reply #1 on: October 18, 2011, 08:08:20 PM »
never mind I found it ....It was in the ports and Pins under Motor Output on the step port and the dir port I forgot to change all of them to 1's
I will be back when I install the probe
