Hello Guest it is June 10, 2026, 09:54:14 AM
Author Topic: Mach3Mill on Windows 7  (Read 8065 times)
« on: October 12, 2011, 04:23:23 PM »
I have a MAXNC 15 connected through a dual parallel port to a Windows 7 PC. Every time I try to turn the machine on, the z-axis motor starts immediately without cause (without opening the software Mach3Mill); so trying to load any g-code is impossible.
After running the memoryoverride.reg and running DriverTest, nothings changed.
Any help would be much appreciated.
Thanks.
andrewm
Re: Mach3Mill on Windows 7
« Reply #1 on: October 13, 2011, 03:33:55 PM »
I'm going to say it sounds like you need to check your wiring. Do you have any signal lines running over or close to power?
« Reply #2 on: October 21, 2011, 04:40:38 PM »
All the wiring are connected correctly. The main reason seems to be the compatability with Mach 3 and windows 7 seeing as the Mach 3 requires windows XP service pack 2. However, I've used an older version of Mach 3 and I've had better process than the most recent version, Mach3 R3.043.022. The only problem with the old version was of the 3 axis, 1 axis was always non-functional. Any suggestions?
« Last Edit: October 21, 2011, 04:42:10 PM by enph »
andrewm
« Reply #3 on: October 24, 2011, 07:20:45 AM »
Make sure you have Run as Admin checked for Mach3.
If its doing it without Mach3 even being used then I cant imagine its the problem, but, doesn't mean it isn't either.
Is the axis starting when you disable the physical E-STOP on the machine?
