Hello Guest it is June 10, 2026, 09:53:39 AM
Author Topic: mach3 & pokeys & 4 MPGs?  (Read 14890 times)
Offline swets
  •  52 52
  • www.arjan-swets.com
« on: October 12, 2011, 02:21:42 PM »
I want 4 MPG on mach3, one for x,one for y ,one for z and one for a.
three works, but is four also possible?
and can somebody tell me how?
(sorry for the bad english)
Offline swets
  •  52 52
Re: mach3 & pokeys & 4 MPGs?
« Reply #1 on: October 20, 2011, 02:12:25 PM »
nobody?
« Reply #2 on: October 20, 2011, 06:57:25 PM »
Swets,
Config>ports & pins>Encoder / mpg's allow for configuring 4 mpg's.
You can set which axis is used by the MPG by clicking on the ALT A,B,C buttons in the jogging flyout.
Maybe save yourself some money / work. I use two MPGS and actualy you can use one for all the different axis.
Offline swets
  •  52 52
« Reply #3 on: October 21, 2011, 02:33:56 PM »
 configuring 4 mpg's?... can only config 3 mpg, or is that what you mean?
so 4 is not possible?
« Reply #4 on: October 21, 2011, 04:11:04 PM »
Sorry, my bad, there is only 3 in config.
Is it possible? Probably...if Mach was rewritten to provide for it.....but then why?
It is the way it is.
Offline swets
  •  52 52
« Reply #5 on: October 21, 2011, 05:17:13 PM »
oke... why... yeah... why not...  but if it not possible than i use 3 for 3 axis... and if i use the 4 axis i change it with alt-a
