May 28, 2012, 08:36:34 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Another 2nd parallel port question
Pages: « 1 2   Go Down
Print
Author Topic: Another 2nd parallel port question  (Read 691 times)
Jackal
Active Member
Offline Offline
View Profile
« Reply #10 on: October 19, 2011, 10:18:40 AM »
Thanks Simpson, Smiley
I got the drivers from the Moschip site and tried them.
Steve from PMDX had me  disconnect my B_O_B and try it on the other (2) added ports ( Rosewill), while changing and going through all the addresses and calling them Port#1.
It never would recognize.
I started having problems with Windows going crazy, and re-formatted the computer. After everything is back to where it was (there is  a good back up of my .xml), I will start again with the port thing.
Thanks for replying,
I really appreciate all of the help on here, Smiley
JAckal
Everything is bio-degradable if you run over it enough with a lawnmower.
simpson36
Active Member
Offline Offline
View Profile
« Reply #11 on: October 19, 2011, 10:33:28 AM »
Couple things;
1) only the fist number in the address is relevant.
2) Mach anomaly (may or may not still be with us in current versions)   For me, Mach would not tolerate changing the address in the config unless I first zeroed the address, disabled the port and closed and restarted Mach. Upon restarting Mach, I could then enable the port, put in a new port address and Mach would use it. Note that this is just an observation and I do not know why it happens this way. I might speculate that this is because the port driver has a death grip on the port while running as a separate process outside Mach, but whatever the cause, I found you have to slap Mach in a face to get it to let go of the address it is clinging to before it will consider changing to a new port address.
Jackal
Active Member
Offline Offline
View Profile
« Reply #12 on: October 19, 2011, 12:31:53 PM »
That is VERY helpful.
It seemed strange to me that I was getting (2) set of address numbers for each port
Ex:
Port #2
       A800-A807
       AC00-Ac07
Port #3
       A00-A007
       A400-A407
Someone  else had told me to use just the first numbers before the (-).
That re-starting Mach  sounds like a good trick.
Simpson,
I sure  do thank you very much,
JAckal  Grin
Jackal
Active Member
Offline Offline
View Profile
« Reply #13 on: October 19, 2011, 07:38:46 PM »
  After reformatting, and installing the drivers and the CNC4PC brain that goes with my pendant, the motor tuning config box still won't open.
I removed  the drivers for the 2nd parallel port, and the CNC4pc brains for the C22 board & pendant.
Now I can run the motor config again.
JAckal
Jackal
Active Member
Offline Offline
View Profile
« Reply #14 on: October 26, 2011, 01:53:44 PM »
It all works now!
 I took out the C-22 board and disabled the brains.
Configured Mach through the port pins and got 5+volts from the USB port.
Hope this helps someone.
It seems the brains had something that  corrupted Mach.
JAckal Wink
Pages: « 1 2   Go Up
Print
Jump to:
