Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 08:26:04 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
loosing the z axis position during cutting???
Pages:
1
Go Down
« previous
next »
Author
Topic: loosing the z axis position during cutting??? (Read 182 times)
Thys
Active Member
Offline
on:
October 03, 2011, 02:49:02 PM »
I have no other way to title this, but let me elaborate,
I use cambam to generate G code and run a program in Mach 3. My lead screw for the z axis is an m8 metric thread with a pitch of 1.25mm. my x and y axis are on a sprocket and chain system and can attain much higher speeds than the z axis. When cutting tonight and 1200mm / min, it seems that the z axis gets out of calibration / position or something as half way through the process, mach 3 shows 3mm above surface, but the spindle is virutally on the wood. ( at position zero) then later, it's even further down at -2 or -3 and mach 3 says the spindle should be at 3mm.
I am not sure but could it be when the spindle jumps over the triangular tabs which cambam makes, it is a little too fast for the metric lead screw to wind up and wind back down again?
It is really frustrating as you could imagine as I loose good wood in the process and waste.
any comments or assistance would be greatly appreciated,
Thys
javascript:void(0);
Active Member
Offline
Carnoustie, Scotland
Re: loosing the z axis position during cutting???
Reply #1 on:
October 03, 2011, 03:05:08 PM »
Sounds like you are stalling on rapids the way up and losing steps, try reducing your acceleration and velocity and see if it helps.
Global Moderator
Offline
Reply #2 on:
October 03, 2011, 03:50:23 PM »
Do as Hood replied. You don't say how long you have used the machine. No matter how you tune .....only after use will you find what settings will be reliable and repeatable. May not like the feedrates and rapid velocities but that's a different topic.
BR549
Active Member
Offline
Reply #3 on:
October 03, 2011, 06:18:01 PM »
The Z axis screw is MUCH to fine compared to the XY axis as far as speed and Stepper RPMs. You will stall the Z every time trying to run high feedrates.
You are going to have to calculate what the best RPM for the Steppers are and then back that into the correct feedscrew rate to get SPEED at the correct stepper RPMs. You may then run into your stepper is NOT powerfull enough to accelerate the feed fast enough once you get the speed up.
(;-). TP
Thys
Active Member
Offline
Reply #4 on:
October 04, 2011, 01:39:18 AM »
thanks so much guys, I think you have nailed it on the head. I will try and improve the setup. Thys
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
