Hello Guest it is June 11, 2026, 04:54:27 AM
Author Topic: Spindle speed control - serial port  (Read 31195 times)
« on: October 02, 2011, 10:36:44 AM »
Hi I have just bought a Texas Microcircuits serial port speed control board (apparently developed by SoundLogic) I have loaded the plugin and using the XML suggested.....nothing narda zip ... an M3 command does nothing at all... Any ideas folks??
Re: Spindle speed control - serial port
« Reply #1 on: October 02, 2011, 12:02:14 PM »
If you are using the parallel port driver you will need to enable the spindle relay option. You dont actually need relays hooked up, just Mach requires you have that setting enabled. You can set up fictitious output numbers for the relays. You will find that setting from Config menu then Ports and Pins then Spindle Setup.
  •  9,356 9,356
« Reply #2 on: October 03, 2011, 01:48:56 AM »
Are the LED's on the PCB operating correctly ??  (do they come on and show CW rotation etc when spindle is turned on/off within Mach - M3 / M5).
Also it is important that you are using the licensed version of Mach and not the Demo version.
« Reply #3 on: October 03, 2011, 05:27:25 AM »
Hi
Thanks for the replies...but..yes the relays are enabled and No LEDs  at all
Could anybody send me a tested XML there are some odd settings in the one I downloaded from Texas microcircuits site (might be right what would I know!)
« Reply #4 on: October 03, 2011, 05:28:00 AM »
Sorry - within Mach 3 leds do come on just fine
  •  9,356 9,356
« Reply #5 on: October 03, 2011, 05:38:18 AM »
Perhaps crossed purposes here  :)
Do the leds on the Texas Micro board operate correctly ??
« Reply #6 on: October 03, 2011, 06:26:09 AM »
Sorry - being stupid . No the LEDS on the board stay off. On the computer screen in diagnostics the output LED flashes.
No sign of life on the board at all
« Reply #7 on: October 03, 2011, 06:38:29 AM »
Attach your xml and maybe someone can see a prob.
  •  9,356 9,356
« Reply #8 on: October 03, 2011, 06:46:30 AM »
I presume you have checked that you have 115V or 240V power going to Texas board and that the fuse F1 is intact (test with multimeter).
« Reply #9 on: October 03, 2011, 07:32:50 AM »
yes fuse and power are ok
I will get back to you with the XML that texas MC provide
