May 28, 2012, 08:13:17 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Input box help?
Pages: 1   Go Down
Print
Author Topic: Input box help?  (Read 270 times)
stevehuck
Active Member
Offline Offline
View Profile
« on: September 25, 2011, 08:23:52 AM »
This is the example from the reference. I'm guessing that the text in the first text box should be returned as TextBox1 but it always seems to equal "". If i'm wrong what variable returns what is input into the text box.
Sub Main
Begin Dialog TextBoxSample 16,30,180,96,"Text Boxes and Text"
OKButton 132,20,40,14
CancelButton 132,44,40,14
Text 8,8,32,8,"Text Box:"
TextBox 8,20,100,12,.TextBox1
Text 8,44,84,8,"Multiline Text Box:"
TextBox 8,56,100,32,.TextBox2
End Dialog
Dim Dlg1 As TextBoxSample
Button = Dialog ( Dlg1 )
Text in textbox one = TextBox1   HuhHuhHuhHuhHuh
End Sub
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: September 25, 2011, 08:31:35 AM »
Add something like:
Text1 = Dlg1.TextBox1
Text1 will be the text in TextBox1
stevehuck
Active Member
Offline Offline
View Profile
« Reply #2 on: September 25, 2011, 08:48:11 AM »
Roger that!
I missed the "Dlg1" part.
Thanks!
stevehuck
Active Member
Offline Offline
View Profile
« Reply #3 on: September 25, 2011, 01:27:49 PM »
Worked like a charm!  Thanks again
Pages: 1   Go Up
Print
Jump to:
