Hello
Guest
it is
June 13, 2026, 08:12:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Problems with movement with Large program loaded
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problems with movement with Large program loaded (Read 10774 times)
method13
71
on:
December 16, 2006, 12:01:24 PM »
I loaded a large cutterpath into Mach2 and when I move the machine it keeps moving after I release the button. It moved fine before and then after I closed the program it would move just fine, but while the program loaded into Mach it had problems. For example, before the I load the program when I would tap the Page up button it would move about .03, but when the program was loaded, I would tap the Page up button and it would move up 1.43 with just one tap of the button!
Any Ideas whats going on? I can get you the cutterpath if you want but its 78Mb.
Greg
"Ideas have consequence" Ravi Zaccharias
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Problems with movement with Large program loaded
Reply #1 on:
December 16, 2006, 12:55:39 PM »
How much ram have you in your computer?
Graham
Brian Barker
3,860
Reply #2 on:
December 16, 2006, 03:59:58 PM »
You can turn off the toolpath for the very large files...
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
method13
71
Reply #3 on:
December 16, 2006, 08:32:39 PM »
I have 768Mb of RAM, Is there a setting that will devote more of my computers resources to the type of applications that Mach uses?
How do I turn off the toolpath, will that make a differences?
Greg
Brian Barker
3,860
Reply #4 on:
December 17, 2006, 09:13:41 PM »
You can turn off the toolpath on the Diagnostics page and it will help with the problem...
thank you
www.machsupport.com
method13
71
Reply #5 on:
December 18, 2006, 01:36:42 PM »
Thanks for the Help, I guess I should have looked harder if it was anymore out in the open it would have fell in my lap.
Brian, check out my other post on "Help this chaos has to stop". Let me know what you have to think.
Greg
Print
Pages:
1
Go Up
« previous
next »
