May 28, 2012, 02:39:21 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  New PoKeys56U was released!!
Pages: 1   Go Down
Print
Author Topic: New PoKeys56U was released!!  (Read 697 times)
borisz
Active Member
Offline Offline
View Profile WWW
« on: September 12, 2011, 11:22:25 AM »
Hi!
New PoKeys56U was released recently. They are 100% replacement for PoKeys55. Mechanical dimensions are the same, all software which works on PK55, should work also on PK56U. New PK56U has more procesor speed and it is prepared for upcoming aditions.
http://www.poscope.com/product.php?pid=28
Here is also comparision between all PoKeys models: http://www.poscope.com/uploads/files/PoKeysComparison.pdf
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
boutje
Active Member
Offline Offline
View Profile
« Reply #1 on: September 15, 2011, 02:40:38 AM »
And what about the plugin for mach?
I could not found a plugin anymore on the pokeys website.
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: September 15, 2011, 03:19:25 AM »
Brian is working on new plugin. You can also use old one from PoKeys55. Will upload it in short also to PoKeys56U site.
boutje
Active Member
Offline Offline
View Profile
« Reply #3 on: September 15, 2011, 03:23:46 AM »
Thanks Cheesy
Pages: 1   Go Up
Print
Jump to:
