Hello Guest it is June 09, 2026, 10:23:54 PM
Author Topic: Video window  (Read 13961 times)
Video window
« on: September 11, 2011, 09:34:39 AM »
Hello,
Is there a ways to disable the cross hair drawing on the video window? Also is it possible to not have the video image stretched to fit the window?
I have a Logitec QuickCam 5000 and the image has pretty big pixel.
Re: Video window
« Reply #1 on: September 12, 2011, 01:33:32 AM »
Hello,
which plugin are you using?
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Video window
« Reply #2 on: September 12, 2011, 05:51:34 AM »
I'm using the one that is included with mach3 (Mach3 R3.043.022) defaults installation. Are there better ones out there?
Re: Video window
« Reply #3 on: September 12, 2011, 06:05:35 AM »
I don't know whether its better, but it could be worth a try. You can download it from: http://www.kd-dietz.de goto downloads plugin camera
Klaus
Re: Video window
« Reply #4 on: September 12, 2011, 11:40:41 AM »
We cant dissable the cross hair in this one either :(
Re: Video window
« Reply #5 on: September 12, 2011, 11:47:53 AM »
you're right, sorry about that. I thought, I had it done already. Give me an hour or two and I will fix it. If you give me your email addr, I'll send it to you, as soon as it's done.
Klaus
Re: Video window
« Reply #6 on: September 12, 2011, 11:59:15 AM »
Klaus,
I can't say it enough, you're one of the kindest people I know, and I don't even really know you -  ;)
Re: Video window
« Reply #7 on: September 12, 2011, 04:11:50 PM »
Hello,
it took a bit longer, I'm having problems with the homepage, but the camera plugin can be downloaded.
Klaus
Re: Video window
« Reply #8 on: September 12, 2011, 07:16:33 PM »
Cool thank you!
Just a few glitch I found... if you are in the pref dialog and hit the "X" of the preff window, both the video and the pref window closes. The DLL version is still reporting as 2.0.9.0 under windows properties.
Re: Video window
« Reply #9 on: September 13, 2011, 05:53:18 AM »
Hello,
I'll fix that, in the near future.
Klaus
