May 28, 2012, 02:32:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  G73 Pullback setting
Pages: 1   Go Down
Print
Author Topic: G73 Pullback setting  (Read 150 times)
BR549
Active Member
Offline Offline
View Profile
« on: September 09, 2011, 12:32:15 PM »
Could someone verify that the G73 pullback setting is NOT being saved in the XML when you change it .
Config , port/pins, mill options, lower center of window.
Thanks (;-) TP
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: September 09, 2011, 01:11:35 PM »
I am sure I have seen mention of that before and have just confirmed it is the case.
Mats
Holding
Offline Offline
View Profile
« Reply #2 on: September 10, 2011, 05:44:57 PM »
It is not saved. It looks like the XML file is updated with the value 0.1 when you exit Mach3.
Pages: 1   Go Up
Print
Jump to:
