Hello Guest it is June 09, 2026, 01:59:11 PM
Author Topic: version 3.043.022, skiping G 53 command's  (Read 12130 times)
« on: August 31, 2011, 02:11:25 PM »
I downloaded the newest lock down version and it is skipping right through a G53Z0 command and a G53 X0Y0 command , i can provide file if need be.
 Thank,s
Re: version 3.043.022, skiping G 53 command's
« Reply #1 on: August 31, 2011, 03:37:39 PM »
Attach the xml and code and I will see if I can replicate.
« Reply #2 on: August 31, 2011, 06:39:35 PM »
I keep getting a error message when it try to post with files . Try's to say i already uploaded the file's
« Reply #3 on: August 31, 2011, 06:48:31 PM »
Ok i renamed them let'see if it takes them.
« Reply #4 on: August 31, 2011, 06:52:18 PM »
It seems to be the M00 command at the end of the first tool that might be causing it MACH does not like M00! but it should still perform the G93 moves before stopping the program.
« Reply #5 on: August 31, 2011, 07:30:22 PM »
Remove the ";".
« Reply #6 on: August 31, 2011, 07:42:49 PM »
So that's the cause , i will have to find another post p , that does not  put that in there or have one modified i may have another i will have to do further testing to see  .  Thank's Hood
« Reply #7 on: August 31, 2011, 07:46:52 PM »
......... and thanks to you as well TP, :)
« Reply #8 on: August 31, 2011, 07:55:32 PM »
The ; is a startpoint for a comment on a gcode line any thing to the right of it is sent to the message bar.
Old school, (;-) TP
« Reply #9 on: September 01, 2011, 01:03:32 AM »
No problem, glad I was of help ;D
Think you meant to say  Thanks Terry.
