Hello Guest it is June 09, 2026, 01:58:19 PM
Author Topic: Barcode Plugin *** Andrew question  (Read 14893 times)
« on: August 31, 2011, 12:19:32 AM »
Andrew I am working with the Barcode Plugin. Is there a NotifyPlugins() call to activate the load Barcode button??
I am working on a system that does NOT have a mouse and I need to create a Button that I can assign a hotkey to to active the barcode function. As it is I have to go to the top menu and select the Plugin control then selct the load barcode selection. Without a mouse that is TOUGH to do .
Thanks (;-) TP
Re: Barcode Plugin *** Andrew question
« Reply #1 on: September 04, 2011, 07:03:17 PM »
I don't know if there is a notify plugin call, but you could turn on a UserLED and the plugin could watch the LED and then run the code.
Andrew
Andrew
MachMotion
« Reply #2 on: September 04, 2011, 09:22:48 PM »
Problem solved Andrew came up with the correct call
NotifyPlugin(10000) . This will set the Barcode plugin into loading mode.
« Reply #3 on: September 04, 2011, 09:52:37 PM »
NotifyPlugins(10000)
« Reply #4 on: September 04, 2011, 11:01:14 PM »
Yep Forgot the "S"
Thanks (;-)TP
« Reply #5 on: September 05, 2011, 07:34:35 AM »
I've been playing with these vbs scripts, very interesting. So much to learn, is there any great resources to grasp this. Not sure I understand what NotifyPlugins() or args.Item(0) are, one looks like a function the other looks like an array element.
Did get myself in one endless loop that kept creating a new script process that I had to reboot to get out of, LOL But it made me understand how the process can be setup as a watchdog or pass data.
Thanks for the lessons, I like.
Ya-Nvr-No
« Reply #6 on: February 17, 2013, 03:49:50 PM »
I still don't get it.  How about walking me through it?
First I create a led and give it an oem value of, say, 1250 and tell it to turn green when active.  Do I need to do anything else?
Then I create a button called 'load file' and give it an oem value of 1250.  Does the NotifyPlugins(10000) go in the Execute VB Script Box?  Do I need to do anything else?  I assume if I set the hot key, it's the same thing as clicking on the button?
« Reply #7 on: February 17, 2013, 04:04:07 PM »
Create a User Button.
Then ad the Code "NotifyPlugins(10000)"  to the button. Then when you press the button it runs the code.
You can assign a hotkey to the screen button if you wish.  Press the hotkey and it runs the code.
Does that help ? (;-) TP
« Reply #8 on: February 17, 2013, 04:27:37 PM »
I believe so.  No led is needed.  No oem number is needed.  The talk about led's had me confused.
The only thing that is needed is a button with NotifyPlugins(10000) entered into the box and the  Execute VB Script button selected.
I set it up like that and it seems to operate correctly.  The problem is I don't want to install the scanner on this machine and the machine I will be installing it on has no connectivity.
« Reply #9 on: February 17, 2013, 04:32:29 PM »
DOes it have a thumb drive (USB) that you can transfer the new screen set ?
Make a copy of your screenset and transfer it to the other machine.  Or load a copy of Machscreen on the other machine.
Just a thought, (;-) TP
