Hello Guest it is June 11, 2026, 06:52:12 AM
Author Topic: Reset button help  (Read 23800 times)
Reset button help
« on: August 25, 2011, 12:38:39 PM »
I have created a wizard to aid myself in some basic day to day stuff. I needed a reset button so i inserted a button and LED. I have the button working ok but the LED, not so much. I have tried every led that would seem to work with the reset button but no light and no flash. What LED should I use to monitor the reset button and flash when the button needs to be reset?
Thanks in advance.
Re: Reset button help
« Reply #1 on: August 25, 2011, 01:26:00 PM »
Here's what the LED dialog box should look like in Screen 4:
Hope that helps,
« Reply #2 on: August 25, 2011, 04:03:40 PM »
Thanks Bud but I use machscreen.
« Reply #3 on: August 25, 2011, 04:22:55 PM »
Ok, then does this help?
« Reply #4 on: August 25, 2011, 05:22:02 PM »
Maybe
I tried to enter the data from your screen shot and the program crashed. Now I can see the led on the screen but i cant select it when I click on it. I'll give it a go if i can figure out whats going on.
Thanks!!
« Reply #5 on: August 25, 2011, 05:43:42 PM »
That worked like a charm. I think when I set it "Global" it moved the led to page zero so I couldn't click on it. All is working good now!!  Thanks.
« Reply #6 on: August 25, 2011, 05:50:55 PM »
Glad to be of help, Steve-
