Hello Guest it is June 13, 2026, 12:20:12 AM
Author Topic: How I solved my Stepper Motor Resonance Problem - Video  (Read 15794 times)
« on: August 24, 2011, 11:20:13 PM »
I have had a terrible problem with bad resonance with the Z Axis on my CNC Lathe.  The problem only appeared at certain feed rates.  The lathe has smooth operation at most feed rates.
In desperation, I had to try to program around the feed rate that I wanted to use (0.25mm/rev) to avoid the resonance; as it was affecting the quality of turned parts. I.e. I would use a non-ideal 0.15 or 0.35mm/rev to avoid the problem.
I tried all the advice that I could find on the internet to no avail. I even changed the Stepper Motor and Stepper Motor Drivers to a different makes.  No luck.  I tried varying the Power Supply Voltage to the Driver with absolutely no effect.
I then tried a mechanical approach by adding a flywheel to the Z Axis Stepper Motor.  Bingo!!!  Why didn't I do this 3 years ago?  So simple and so effective!!!
The video shows a wobble in the flywheel which resulted from my poor hand tapping skills.  I will make a new flywheel when time permits; now that I seem to have the problem licked.
The flywheel is Ø99 x 14 thick and made from mild steel.  There was absolutely no maths used; rather a simple application of the laws of physics and gut feel!!!
See video here  http://www.youtube.com/watch?v=mqCL7g4gwAU
Regards
Chrisjh
Re: How I solved my Stepper Motor Resonance Problem - Video
« Reply #1 on: August 25, 2011, 10:40:25 AM »
Big difference indeed :)
Offline Haik
  •  71 71
  • MachUser
« Reply #2 on: June 13, 2013, 03:01:56 AM »
Inertial Dampers and flywheels are very effective for helping nullify resonance within a rotational mass. Here is my NEMA 42 stepper with a multi-part damper at work...
« Last Edit: June 13, 2013, 03:05:11 AM by Haik »
« Reply #3 on: June 13, 2013, 06:03:16 AM »
Good Job Chris!   :)
« Reply #4 on: June 13, 2013, 04:15:27 PM »
Here's an old thread showing how to make a "rattler" style stepper damper.  It's very effective.
http://www.cnczone.com/forums/stepper_motors_drives/32284-take_stepper_damper.html
Milton from Tennessee ya'll.
« Reply #5 on: June 15, 2013, 06:11:21 AM »
I have been using this flywheel mechanical damping system successfully for a couple of years now.  It is interesting to place your hand lightly on the revolving flywheel when feeding at 0.25mm/rev, to feel a very distinct "pulsing".  It actually feels quite violent.  But the end results (finish) speak for themselves.
Obviously (hindsight is a wonderful thing), my resonance was purely mechanical and, probably the result of length and elasticity of ballscrew shaft combined with other moving masses at one particular frequency.
Regards
Chrisjh
